Question about Kenmore 74602 Gas Dryer
Kenmore Gas Dryer not heating. (74602)
Kenmore Large Capacity Gas Dryer Model 110.74602300 When my dryer has not been used for a while, it will start drying when first turned on. But soon afterwards, it will not heat. I have cleaned all duct work, verified the all temperature sensors are working. When the gas tries to turn on, the igniter glows and you can hear a vibrating noise (not buzzing) coming from the gas valve area. No gas comes on. I looked at the schematic and it indicates that the igniter should be 40 ohms. I unplugged mine and measured the igniter resistance and it was 100 ohm. (I have not measure coil resistance yet). Could this be the problem or could one of the coils be bad, even though they appear to work as least once when first turned on. Or is there something else wrong.
  • 2 more comments
  • James Wray Sep 25, 2007
    Fixed!!
    Solenoid coil was bad on gas valve.
  • Anonymous Dec 06, 2007
    i have a kenmore 70 series gas dryer and i have no heat i cleaned all the ducts out what should i start with.
  • Anonymous Apr 03, 2008
    I have the exact same problem with my gas dryer. I have an Amana Model No. PLG153LM. It appears to heat at first when turned on, then it goes cool very soon. It appears not to cut on heat while trying again unless the dry is left alone for a long period of time. Thomas
  • Anonymous Apr 01, 2009
    hello my name is ben and my dryer will not heat up , the outside vent was compleatly pluged up and it looks air tight , were is the thermal fuse at or does any one know whats wrong
I have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Posted on Apr 01, 2009
  • superjet511 Mar 03, 2011
    I had a similar problem, but no clogging of the vent. I actually found a schematic under the control panel cover and started diagnosing the valves, igniter and safety switches. Everything looked good and there was actually ohm specifications on the supplied schematic. I moved on to the thermal fuse located on the duct which read 49 ohms of resistance. I purchased a new thermal fuse online for $3.45 including shipping and installed it. The dryer fired right up and is working properly. All I can figure for the failure is that the dryer is somewhat old and maybe the thermal fuse was weak....
Have a Maytag dryer, appears igniter is not working. Should the resistance be readable using a standard ohm meter? Or is it extremely high resistance giving the appearance of being open?
Posted on Jan 13, 2008
SOURCE:
DRYER DOES NOT HEAT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 13, 2011 | Kenmore 74602 Gas Dryer
No heat checked all vents and gas lines. don't know whats next?
A gas dryer uses a electric igniter that glows orange to light the gas burner. If the igniter does not glow orange when the dryer is started..replace it.
Jan 12, 2011 | Kenmore 74602 Gas Dryer
My Kenmore pilotless gas dryer is not heating. How do I replace the starter?
there's more than one part in there that could be bad,is the ignitor glowing? and send model number
Sep 03, 2010 | Kenmore 74602 Gas Dryer
My Kenmore Gas Dryer Model 110.97584120 does not get hot. The drum rotates. There is no problem with the buttons. Help, please. Thank you
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
Kenmore gas dryer that turns but does not heat up
No heat at all? does the top of the machine heat up, but not the drum? could be your drum seal is damaged or slipped off.
If the firebox doesn't light up, could be your igniter, the unit's safety switch, thermocouple, or regulator; Your Gas Company may provide a service that would check it for you... some do.
Jan 02, 2009 | Kenmore 74602 Gas Dryer
Manual for a Kenmoore 60 series soft heat large capacity dryer.
Here is the website for Kenmore driers and the manuals to download for free in Adobe format. They are only listed by model number.
http://www.kenmore.com/shc/s/search_10154_12604?vName=Kenmore&cName=Washers+%26+Dryers&keyword=kenmore+drier&sLevel=0
Dec 22, 2008 | Kenmore 63942 Dryer
I need a schematic for Kenmore dryer number 417.93052201
sears.com enter your model theyll have a wiring diagram there for you
Mar 06, 2008 | Kenmore 74602 Gas Dryer
3 yr old model purchased used, not heating up
I would be concerned that when they disconnected gas flex from dryer, that the fitting on dryer turned with the pipe that goes into dryer and that it came undone.
Nov 25, 2007 | Kenmore 74602 Gas Dryer
Kenmore 74602 Gas Dryer Logo
6,705 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
