Question about RCA F36650 36" TV
Picture quality picture jumps & there is a black line @ bottom of screen as if the top to bottom alignment is off. this just started happening with no warning
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in vertical section 1 check for proper supply. 2 some capacitor in that section is faulty. not a major problem. it is COMMON PROBLEM can be fixed easily.
Posted on Oct 01, 2007
SOURCE:
Thin red line appears on screen. Purchased Nov. 2007
the minute parts near the picture tube might have misaligned ,,,,,, you need to align those parts .... contact a good tv mechanic .... he will use a magnetic type material and align every minute parts correctly near the picture tube, the red line wont appear again
Mar 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
[email protected]
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Screen border
You are probably in the "3:2" ratio print setting. This is accessed through the "F" button, under image quality. The 3:2 is a ratio of height to width which corresponds to a 4x6 inch print. The other settings are approx. 4x5.33 inches in h to w ratio. Just change the quality setting to the larger megapixel settings and the bars will disappear.
Sep 21, 2008 | Fuji FinePix S700 Digital Camera
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Samsung HDTV top of screen is turning inwards
Mine is Same, Just got it back from repair shop. Two Convergence Chips Replaced. $220.00 Got it home and picture was perfect, after about 1/2 hour I now have the Line back and top curving. I suspect bad soldering
Nov 14, 2007 | Samsung HCM5525W 55" Rear Projection...
RCA F36650 36" TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
