Question about Hunter Ceiling Fan Light Remote Control
Fan and lights comes on automatically
I installed an fan and light conntrol, this what happen the light comes on automatically even the switch on the control is off. i do have 2 fan and light control throughout my home. both of them do the same thing. they are both hunter fan controls
    Sniper:
  • 52 Answers
· If you installed more than one remote-controlled ceiling fan, set the DIP switches on both receivers and the control of one fan to an identical alternate sequence (such as "all up" rather than "all down"). Otherwise, when you turn off the ceiling fan in one room, it will turn off the fan in the adjoining room. You can also go to the internet and enter GOOGLE.com in the GOOGLE search box enter Hunter.com homepage. You should find all the help you need there.
If you found any of this information helpful, please rate my solution. Thanks D. Lange
Posted on Apr 24, 2009
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
My hunter fan light can't be turned on/off with the light switch
The switch will only turn the power on to the fan/light. You have to use the remote to dimm the light & change the speeds. You should be able to install it on the wall next to the switch so you can turn on your light when entering the room.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Pressing power button results in power light and hard disk light coming on for a couple of seconds cpu fan spins for same length of time then fan stops lights go off few seconds later lights come back fan...
it seems that you have damage memory card replacing may fix a problem but its better for it that you bring it to a technician in order to check much better because the motehrboard may possible be the problem.
Jun 30, 2011 | Acer Aspire 4315 Notebook
After installation fan and light will not work
Did you make sure the wire nuts were tight in the fan and in the box? Is there a switch controlling this fan?
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Magic fan
u need to show a good technision of electronic
Jul 19, 2008 | Hunter 21617 Palermo Brushed Nickel...
Magic fan
Sounds like a defective infrared sensor in the fan. I assume you have tried removing the batteries in the remote to rule out the remote. I don't think you have a wiring issue....your light works and the fan works. Typical fan wiring involves the fan & lights. The wiring for the infrared should already be wired from the factory. Its in the infrared detection circuit.
- Jim
Feb 12, 2008 | Hunter 21617 Palermo Brushed Nickel...
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Dryers Logo
786 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
