Question about GE (PSS26MSRSS) Side by Side Refrigerator
Compressor hmms or moans on refrigerator when it cycles
"the freezer part of my refrigerator cycles now with a loud off and on hummm up and down what should I do"
In the past before this is used to make a howling sound off and on. I unloaded the icemaker and that didn't help.. It just sounds like the motor struggles. It is only 4 years old. My manual says that high pitchedd hum or pulsating sound while it is operating is norma.. for a high efficiency compressor. It really did not do it so much in the beginning. Should I put less food in it or clean the condenser? How do you do that? Thnak you for your help in advance.
  • vltime Apr 24, 2009
    It could be I will try it on Saturday, thank you for the suggestion.
    Scholar:
  • 126 Answers
There is a fan behind freezer compartment upper back plate. it could have ice around it,panel could be shoved against it by food. you just have to empty freezer and remove panel to know for sure
Posted on Apr 23, 2009
GE SIDE BY SIDE ICE AND WATER. FRIG MAKES A LOUD MOANING SOUND . EVERYTHING WORKS OK, EXCEPT FOR THE NOISE.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 27, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Kenmore top freezer, Refrierator shuts off with loud clunk.
It sounds like you may have a compressor that is working hard against high pressure due to a dirty condenser or a condenser fan not running or blocked. If all is well otherwise, the mounting springs inside the compressor may have broken or are weak. The only fix then is a new compressor.
Jun 22, 2009 | Kenmore 64802 Top Freezer Refrigerator
At only one year old the compressor had to be replaced. Now when it cycles there is this whirling sound that is loud enough to keep you awake. What the heck is it? That noise was not there before.
Not as much as likely the compressor again. I think your fan inside the freezer or under the refrigerator may be hitting something like ice or the housing the fan blades spin in. Could also be the blades are loose or out of balance. The only way to track it down is open the freezer and listen or move the refrigerator away from wall and take the cover off of the compressor compartment and look and listen. I would not like that noise myself. If you need anything please let me know. I'm here to get you fixed, Thanks Sea Breeze. Oh if this is helpful please rate me thanks.
Jun 10, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I have 10 year old Roper refrigerator. Frig is a
the thump is your compressor shutting off.you can try changing the rubber grommets but most likely your compressor is just going to be loud until it finally dies.
Mar 05, 2009 | Refrigerators
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Freezer moans
Got a tape recorder or video camera?  Tape it and then call the service guy.  Then if it's "not" acting up when he gets there you can show him!  I did that once...it works.
Oct 25, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Stainless Steel Side by Side - Loud Huming and Whoosh noice
you should not hear it from that far away. It sounds like it may be compressor related. The only thing you could check to make sure is remove the lower rear cover and check the condensor fan and listen to the compressor to see if thats where the noise is cmming from. Check the fan in the freezer too.
Aug 06, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
213 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
