Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Light switch appears to have failed. Light sometimes come on when the door is opened but now, it does not come on regardless of toggleing the switch.
I have an 8 year old GE Profile side-by-side refrigerator. It works fine except that in the past few months, the interior lights will not go on when the door is opened. I toggled the small rotator switch on the upper inside of the door and sometimes, the light will come on. I removed the switch today and examined it but no apparent breakage and the two wired are securely fastened to the terminals. Now, the light will not come on regardless of toggling or repeated pressure on the switch. I assume the switch has failed but cannot find a part number nor anything on the GE troubleshooting website to solve this problem. Can you help? **** Wimberley, Texas
  • dns04 Apr 23, 2009
    Dennis,
    Thanks for the possible solution to my refrigerator light problem.  I have changed all the light bulbs several  times with new ones but that is not the problem.  I am positive that something is wrong with the little rotor switch in the door because when I wiggle and toggle it a few times, the lights will flash on and then off. Is there a place to buy a new switch or get this one repaired?
    Sniper:
  • 52 Answers
This may be as simple as changing the bulb and not the switch. There is a good chance the bulb was loose and barely making a connection or the filament in the bulb was about to burn out. If this has been helpful please rate the solution.
Posted on Apr 23, 2009
My whirlpool gas dryer stops running.It stops with heat or no heat.I have held the door switch with the door open and it still stops.Sometimes it will run a minute sometimes a few seconds
If it runs when you hold the switch but intermittently when the door is closed, you might need to either replace the switch or the toggle on the door. See if you can bend or adjust the toggle on the door that closes the switch to fix it or if you can't, try replacing it first since it is the cheapest solution. Switch, based on what you posted, sounds fine. Who knows, maybe one is simply depressed from slamming the dryer door closed too many times?
Jan 15, 2018 | Whirlpool Dryers
My radio stays on after i turn the ignition off in my jeep and as well the dome light stays on, sometimes it'll go off and sometimes stay on, weird...can anyone help? One time the radio was off but all the...
It sounds as if the door switch that toggles on and off for open door or closed door is defective or it is a problem with the timer associated with same.
Oct 29, 2014 | 2008 Jeep Wrangler
My honda odyssey ex 2008 the doors do not move on
Do a reset on the door system, by pulling the door fuse. I don't have location, possibly drivers side fuse box.
Sep 15, 2014 | 2008 Honda Odyssey
Locked keys in car get door open
door switch fail just need to change it or free it up. you will find a switch on the door behind a rubber gromet the door open the light comes on door close the light goes out and the switch tell system doors closed. more common to be the drivers door as this is the most used door. failing that there is a second switch in the door lock mechanism to get to this one you need to take the door card off, these can sometimes get damaged if some try to jimmy the door.
Mar 19, 2014 | BMW X1 Series Cars & Trucks
1997 Camry -rear left door won't open from inside. Linkges and snap on clips appears to be OK. Toggled the child saftey lever many times but the problem remains. What to do next and how?
really sounds like a linkage is off somewhere, could be up at the release inside the door,Sometimes hard to see. Could also be in need of some oil. make sure inside handle is not broke also. hope this helps and good luck.
Aug 12, 2012 | Toyota Camry Cars & Trucks
Problem with power door lock and warning light.
It may be as simple as a failed door switch. It would appear one of the switches has failed "open" keeping the light on and not allowing the locks to lock. Check each switch to see if you can find an issue with one, perhaps the plastic plunger broke and when the door closes it will not open the switch.
Please let me know if this assisted or if you need additional help.
Thank you,
Tom
Jun 07, 2010 | 2000 Mitsubishi Galant
Accident turned on self clean with door open
I tried pushing in the light switch again, and i pushed it in until it stopped, evedently it is a 2 postion switch, when the door locks it pulls the door up tight, and the switch must sense this, so after I pushed the toggle in flush the lock finished locking and while I was still holding in the light switch I pushed the stop/cancle button and the lock opened up,and vola we could use the oven again, we had pizza.
Apr 11, 2009 | Kenmore Kitchen Ranges
Door Ajar Warning Light Stays On
Our Ford Expedition & an Olds Silhouette Premier & both did the same thing. Someone online said to spray the inside door where the metal connects with the frame & sensors are there with WD-40. We did & it fixed the problem. Maybe this will work for yours.
Aug 14, 2008 | 2000 Oldsmobile Silhouette
Kenmore Trio 596.75509400
Generally speaking if the refrigerator does not cool and you have frost on the back wall of the freezer it suggests a defrost problem.
However since the refrigerator started working by itself it would point to an air circulation problem from the fan in the freezer compartment failing to operate. The frost on the back wall without the fan operating would cause frost buildup because the heat is still trying to get to the coil through the back wall. If your refrigerator freezer has a door fan light switch something holding the door partly open would cause the fan not to operate. Look for a button or toggle and manually push it in. You should hear the fan turn on and the light will go off.
Mar 12, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
