Question about Rockford Fosgate Punch 401S Car Audio Amplifier
Amp cutting out
My amp cutts out for a second or two after about 15 minutes. Originally i thought i wired my amp and subs wrong but this is not the case. The amp does get warm. I have my gains turned almost all the way up and I dont have a farad cap. Could one of those cause this?
  • 47 Answers
Sounds like your amp is over heating. it wouldnt have nothing to do with a power cap as it would just die. your making your amp work to much. look into bying a line driver as this will boost the volume going into the amp wich will also make the subs louder
Posted on Apr 23, 2009
Crossfire vr2000d wont stop cutting out
Bad ground, possibility of some wires touching
Oct 25, 2017 | Crossfire VR2000D Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
Amp or something cutting out.
Power caps store power from the battery and they feed constant power to the amp so you dont get no drainage! this could be one reason..
have you bridged both subs and wat gauge wire are you using.
these amps can only handle one bridged sub at 4ohms and this amp is recommended that u use 8gauge or higher. if your running to subs i normally reccomend using 4 gauge power wire as you get more rms power feed to the amp
you can get a power cap or anyother accersory cheap online at my suppliers.. caraudiosecurity << click to enter >> hope this helps and please rate me :)
Apr 22, 2009 | Rockford Fosgate Punch 401S Car Audio...
Amp or Stereo Cutting out...
I agree with what you think it might be. I really think its the deck that is bad and you should be able to take it back for a new one. Have you tried unplugging the RCA cables to the amp to see if that stops it? That would tell you if the amp is backfeeding or doing something weird.
Mar 02, 2009 | Dual Car Audio & Video
Amp staying on but cutting out?
Hello Willb2396,
Actually you answered your own question in your paragraph. I draw your attention to your statement of:
"It will work for as long as I'm driving I will park my car, and when I turn it back on every thing will be working just fine and, then a couple minutes later, amp cuts out and won't hit for a couple hours or a couple days.... I have checked the sub multiple times and I don't see it being the sub or the amp"
You are correct it is neither the Sub nor the Amp. The problem is either your voltage regulator or your alternator. one and or the other is going bad.
Here is some advice check your ground wires, the buy a dual alternator kit, it contains the parts you will need to add an additional alternator to your car. This will provide the power you need.
I hope this helps,
Thank you,
Shuttle83
Nov 10, 2008 | Alpine MRP-M650 Car Audio Amplifier
Music not playing from subs
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I did what you suggested..
Take it to a car audio shop that has test bench and ask them to check it for you.
May 07, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
AMP FOR SUB SHUTS OFF SOMETIMES
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Protection Circuit
Yes, always a good idea to use a wire wheel and drill to get a super clean place for your ground. That was going to be the first thing I suggest. I would use a meter and see how many ohms the subs are at right now. It may be two low and there is too much current demanded form the amp at once. for a good sub wiring guide, go to
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html
Don't forget to leave feedback.
Jan 23, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Amp not powering up??
the sub amp may be damage, shorted. you may have a wrong speaker hook-up the first time you use it. too low impedance may have damage the sub.
May 15, 2007 | Kenwood KAC-8101D Car Audio Amplifier
Rockford Fosgate Punch 401S Car Audio Amplifier Logo
117 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
