Question about RCA HD52W56 52" Rear Projection HDTV
I have a hd52w56 52in rear projection tv. my picture will not align. the screen shows 3 bands of color (red, green, and blue). i looks like it could be a 3D picture. how can i fix this issue?
  • g19marsha Apr 23, 2009
    there is no covergence setting. also had the wrong model number, my tv is a r52wh77. i see in the manual there should be a convergence setting but theres not, i've tried every possible option from the menu screen.
  • 15,935 Answers
You must align the color lamps - it is called setting the Convergence.
Check your owners manual for the steps for your particular model.
Do you have your owners manual?
if not... please reply by using the "continue with this expert" option so we are re-connected.
Thanks!!
Posted on Apr 23, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Apr 23, 2009
    go to setup, scroll down to convergence, and choose auto convergence
  • blueextc3221
    CLICK HERE for your manual in PDF format
  • blueextc3221
    (page 44 of the manual)
    Go to the main setup menu
    choose option #1 - Picture quality
    Highlight Convergence and press OK
    Manually go through the setup to align the colors.
    Directly from page 47....
    The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’
    images are precisely aligned, they create the color images you see on the screen.
    Over time, the picture can drift out of alignment (this is normal). If your picture
    seems fuzzy or has a yellow tint, using Convergence could correct this
    misalignment. Only one convergence is needed for all inputs, regardless of the
    signal format.
    Note:
    Make sure the TV has been on for at least 30 minutes (TV needs to
    warm up for best results) before starting Auto Converge or Red/Blue
    Centering.
    When you select the Convergence feature, a submenu appears with three options:
    Auto Converge
    Automatically aligns the projection lenses to self-correct
    color images. You’ll see flashing squares of color dance across the screen
    (this is normal).
    Note:
    After performing auto convergence, use the Blue Centering and
    Red Centering menus to fine tune convergence in the center of the
    screen, if necessary.
    Blue Centering
    Aligns the blue and green images to fine-tune the
    picture.
    Red Centering
    Aligns the red and green images to fine-tune the picture.
    Note:
    The ability to change channels is disabled when adjusting the
    convergence options. The TV must be tuned to a usable signal to
    converge the picture.
    If you require more clarification about this question - use the "continue with this expert" option... however this will fix your color issues.
    Thanks for using FixYa!!
  • blueextc3221
    Oh - ok... if thats the case there is a blown fuse that is pretty easy to get to.
    Try looking at the main board very near the flyback and you should see 3 fuse links (they look like hard capacitors) one of them is probably open causing lack or power to the convergence board by way of the ribbon seated close to the vertical output IC
    I believe the fuse is designated FL231 on the F/B board.
    Kinda hard to get.... rca part number 259213 .4 amp. The reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this fuse on the main board it is a fast and easy repair.
    Here are exact instructions....
    FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and green shadows? Does it have bowing in affect on the top and bottom of picture? when you turn it on does some thin red green and blue line bow in from the top then go away. The main question to determine if you have the fl231 fuse problem is if you go into customer menu then setup do you have the "CONVERGENCE' option. If you do not. then i suspect you have this problem. In the manufactering of these sets Lead free solder is used. now there is great debate over the use of lead free. connection tend to be more brittle. cracks develop around the solder connections of the high voltage flyback transformer. this very small crack set up oscillations in the cuicit with a 400 milliamp fuse. THis fuse cant take it. When this fuse blows the processor then does not know its a projection tv with three projection tubes. it thinks its a crt tube tv. and crt tube tv dont need "convergence" so it removes the convergence from the set.
    TO REPAIR... 1. Warning. this set can generate leathal dangerous voltages even unplug do not attempt if you have no experence with electronics.
    2. Remove the back. there a number of torx 20 screws.
    3. what you will see is a number of circit boards There will be one on the right and one on the left. the one on the right is the small signal board. the one on the left is called the power deflection board. it has a large black part with a big red or black wire coming from the top, this is the flyback.Next to the flyback on the right of it there will be three small rectangular componets tan or brown in color. these are fuses. the one in the middle is the fl231 fuse.
    4. getting to this fuse can be difficult. these two cuicit boards sit on a tray that is removable. to remove this tray it is pulled out and up. BUt watch the wires.loosen the wire tyes.
    5 when you get the tray up the bottom side of the board can be accessed
    you will now have to unsolder that fuse. one side of this fuse is under a plastic part of the tray. i have found the easest way is to cut away the plastic to get to it. if you dont want to do this you will have to remove the board. only remove half of the plastic brace
    6. REPLACE FUSE RCA PART 259213
    7 RESOLDER FLYBACK CONNECTIONS simply heat up and add a little solder
    8 reassemble set. make sure you examine the set for loose connections.
    9 and remember "BE Careful'
    NEVER OPEN BACK OF SET OR ATTEMPT ANY REPAIR WITHOUT FIRST UNPLUGING SET
    Very important..... Remember to solder the flyback connection. I have seen this set come back to the shop every time if i didnt resolder these connections!!
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
Mar 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Red Alignment problem on a Hitachi 51inch rear projection tv
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2009 | Hitachi 51F500 51" Rear Projection...
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
RCA HD52W56 52" Rear Projection HDTV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
