Question about Poulan "Poulan" Push Mower
The mower is stuck at high speed, how do i idel it down
The kill switch lever cable does not work and i cant idel down the engine. i can start it but i cant idel it down . how can i do it.
    Sniper:
  • 52 Answers
If you have a Lowes, Home Depot, etc... near you, I would suggest you replace the throttle cable. If you don't want to purchase a new cable then try spraying the top and bottom of the exposed cable with "liquid wrench or WD-40" then push and pull the handle until the cable begins to freely slide inside it's casing. If this has been of any help to you please rate my solution. Thanks D. Lange
Posted on Apr 23, 2009
Throttle on 14SZ not working, stays in low
CABLE STRETCHED..OR THERE WILL BE AN ADJUSTMENT TO CABLE SOMEWHERE...LOOK! SOMETIMES ADJUSTER IS AT LEVER..LIKE AN AUTO HOOD CABLE
Sep 09, 2012 | John Deere Garden
My' MTD riding mower will not start? the battery is fully change? but just will not started. when I check the oil? it was not good; it was very black, and the oil lever was very high above normal
can you rotate the engine by hand?try and bypass wiring and jump at the starter if ok they bypassing the safety switches and bypassing each battery cable
Apr 21, 2012 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need to know how to set the throttle so can turn off with cable control instead of having to pull spark plug each time
I need more details to answer this with one statement, but I will give you some solutions based on my experience.
Newer lawnmowers have a dead man lever which will either shut the engine off immediately or stop the blade by the use of a clutch system. If it the dead man lever, it just needs to be released. If the engine has the blade stop, then the throttle cable would control killing the engine. If the mower is really old (>20 years) then the only way is the throttle cable.
To adjust the throttle cable:
Follow the throttle cable down to the engine, it will terminate by the carburetor. There should be a single screw where the cable attaches with a clamp that goes over the cable. Loosen this screw and you can adjust the cable forward or backward to adjust the position (ever model is different based on throttle cable and engine configuration). You can figure the direction out by pulling the lever to the slow speed/off setting and watch the motion of the cable at the carb. If the cable pulls inward then you have to move the cable assemble away from the carb. linkage. This will allow the throttle linkage to pull closed further.
If you pull the air cleaner off, you should be able to see how the throttle linkage and cable interact. There is a ground wire that connects under the linkage, which when shorted out kills the ignition system and the engine turns off. If this wire is not in place or something else is preventing the wiring from shorting out, you will not be able to kill the engine no matter how much you adjust the linkage. If the wire and switch seem to be in the correct place and the throttle linkage is working, but it still doesn't kill the engine, just short the wire out directly to a clean metal surface to verify the condition of the wire.
Nov 19, 2011 | Garden
Toro 200-43 name sr-21s serial # 200012530 pulls hard to start but won't start pulled spark plug still pulls hard and no spark
Sounds like the engine stop cable has stretched or broken and is not releasing the engine brake. This cable also disengages the kill switch to the ignition module. Follow the cable from the upper handle down to the side of the engine and watch how far it will move the brake lever. If it is less than 3/4 of an inch, the cable will need to be replaced.
Sep 06, 2010 | Toro Lawn Mower With Toro Power Tools
My yard machine will not shut off after i let go of throttle
Safety switch sticking. Is the cable slack when you let go of the bar? Does it start even if the handle isn't squeezed? If it is and does then cable is frozen or the kill switch is stuck in the open position.
Lube the cable and check the kill switch
Get some WD40 and trace the cable back to the motor. Look at the kill switch assembly and locate the pivot point on the switch where the cable hooks to it. Spray it good then spray the cable at both end letting the lube go in the cable housing. Work handle lever and then see if it works.
May 23, 2010 | Mtd 22" Yard Machine Push Mower
Mower cuts off when blade is engaged.
Not familiar with this model, but a thought, check for a kill switch.
Apr 27, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
10 hp briggs runs at high speed, govenor don't seem to be working
One possible cause for this problem is debris,sticking,or frozen linkage between the governor and the throttle butterfly. Depending on the make and model of your engine it will either be a mechanical governor that has a arm that goes down into the case or a air vane governor that is behind the recoil shroud of the engine. Move all the linkage that connects between the governor and throttle and speed lever to make sure it doesn't bind or sticks. If it does pray a little silicone or wd 40 spray on it to help reduce friction. Also on air vane governors they can become stuck from debris that inhibits it from moving make sure there is nothing in the way of the governor. If all of the linkage is working properly and you still have the issue try adjusting the the fuel mix screws and the high rev. settings on the throttle lever (if equip.).
Jan 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Kill switch on handle
I presume it is the throttle switch as well, as most of the mowers have the kill switch there.
the plastic throttle handle should have a round pin at one end which connects to the throttle cable, there is usually a plastic outer cover that is retained by a threaded screw which holds it all together on the handle,
there may be a small screw at the top of the plastic throttle cover which is the adjusting screw for the throttle cable, if you loosen it, pull the throttle lever right back and push the screw down until it stops and then tighten it that will adjust the cable and should shut the engine down when the lever is pulled right back
Apr 02, 2009 | Garden
1993 geo tracker engine idels high all the time
you need to post
8vlave
or 16valve motor
they can be either.
but there are 50 things that can kill idle.
air leaks
ISC valve stuck
ignition timing too far advanced a idle.
and many more
tell more , get more.
Feb 18, 2009 | 1993 Geo Tracker
Poulan "Poulan" Push Mower Logo
236 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
