Question about NEC 90MHz P8 CPU (1580261940) Motherboard
Laptop a friend downloaded spybot on2 my laptop which is currently not connected 2 the net,after he completed the download i clicked on2 it and it did nothing and it is now flashing orange down the bottom of my screen but does nothing!how do i get rid of this problem??thank you.
    Problem Solver:
  • 10 Answers
What version of windows are you facing here ?
Posted on Sep 24, 2007
SOURCE:
Hey I was really hoping that someone could help me figure out for sure what pins I need to do in order to flash the bios on my Dell Inspirion 1525 with board U53. I thouht it was the 4 and 6 pins but my...
you do not have to change any pins on your laptop to flash it.
go to this link below to download the latest bios
http://support.dell.com/support/downloads/download.aspx?c=us&cs=22&l=en&s=dfh&releaseid=R246843&SystemID=INS_PNT_PM_1525&servicetag=&os=WW1&osl=en&deviceid=15720&devlib=0&typecnt=0&vercnt=6&catid=-1&impid=-1&formatcnt=0&libid=1&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=358934
  1. Click Download now.
    The File Download window appears.
  2. Click the Save button.
    The Save As window appears.
  3. Select Desktop using the drop-down menu to the right of Save in.
  4. Click the Save button.
    A progress meter moves as the download is completed.
  5. If necessary, click X in the upper right-hand corner of the Download Progress Window to close it upon completion.
Mar 28, 2011 | Dell Computers & Internet
I want to make my internet faster to surf as well as download.
There is no such software to increase internet speed. However if you keep your PC clean...it'll increase your net speed a bit
Scan your PC with 1. Spybot http://download.cnet.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html
2. ccleaner http://download.cnet.com/ccleaner/
Sep 30, 2010 | Computers & Internet
Lost the cd of net connection driver
If you have lost your cd then dont worry just open the website of your correspondence laptop or pc. Then open supports and Driver downloads. After that downloads net connection driver. And then create a new cd....okay friend
Aug 19, 2010 | Computers & Internet
When you go to LAN settings in the connection tab internet options on internet explorer, it has the port # and address right? What is the port # and the address? I think internet and explorer and very...
Firstly, disconnect your PC from the Internet AND shut the PC down.
This is incase it has a virus that is causing the problem.
Using another computer download SpyBot Search and Destroy from the Internet.
To do this you will need a USB Stick and another computer with an internet connection.
1. Navigate to SpyBot.com.
2. Pick your Language.
3. Click the SpyBot Search and Destroy link under the heading Products.
4. Click the Download icon adjacent to the SpyBot Search and Destroy application.
5. Select the destination to save the Application to. This will be the name of your USB stick.
6. Then click the Download icon adjacent to the Detection Updates and save them also to the USB stick.
Whilst you are on SpyBot's website, navigate around the site and see how to use the software.
Essentially, when the virus is particularly malicious you need to run an application that can detect the virus, and the PC should not be connected to the internet. You will also need to run the PC in SAFE Mode.
Consult with your PC's website (ACER, DELL, HP etc...) to find out what button to press to put it into SAFE Mode as you power on the PC. Some PC's it is F8.
You will need to turn on the PC and then press the appropriate button. Select the option to start the PC in SAFE Mode.
When started up connect the USB Stick.
Navigate to the USB Stick and Run the SpyBot Application from the Stick.
NOTE this will take some time to do depending on the amount of programs and files on your PC.
If SpyBot finds Malware etc.., get rid of it.
Note: When your PC is free of viruses then you can copy the SpyBot application to your PC along with the Detection Files. Then you can open SpyBot and set it up for Auto Scanning. Then, you can re-connect to the Internet.
I hope this helps. Regards,
Feb 09, 2010 | Microsoft Windows Vista Home Premium...
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
My hp pavilion dv1000 will no longer connect to the internet.
Hi !
1/ downloading spybot search & destroy
downloading smitfraudfix
2/ restart pc with safe mode
3/ launch spybot
at the end remove (delete) all files
4/ launch smitfraudfix
press a key to continue
press 2 to clean
5/ restart pc with normal mode
re-launch smitfraudfix
press a key...
press 5
search and clean DNS hijack
restart PC and it will be better...
Feb 28, 2009 | HP Pavilion dv1000 Notebook
I have lost original CD with printer software
PRINTER DRIVER DOWNLOAD.
1) Go to http://www.epson.co.uk 2) Click on PRINTERS, select INKJET, and then select your printer from the list. 3) Select on WINDOWS under DRIVERS AND DOWNLOADS. 4) Select the most current version of the driver for your operating system and click DOWNLOAD NOW. 5) Respond to the Download Survey and ACCEPT the license agreement. 6) Make a note of the file name and save the downloaded file to DESKTOP in order to easily retrieve it.
Automated USB Driver Install
1) Before beginning, ensure the cable for the printer is disconnected and the printer is turned off. 2) Locate and double click on the downloaded driver installation file. 3) Click on OK at the first WinZip screen. 4) Click on UNZIP at the second WinZip screen. 5) Click on OK when WinZip is finished extracting files. 6) At the PRINTER UTILITY SETUP screen, click on OK. 7) The installer will now copy files to the computer. When this step is complete, it will tell you to attach the cable and power on the printer. Please connect the USB cable and turn on the printer. 8) The computer will install the new hardware. 9) Click on OK when the driver installation is completed.
Your printer is now ready to use.
Nov 24, 2008 | Epson Stylus C46 InkJet Printer
I HAVE A VIRUS ON MY LAPTOP! HELP!
I had the same problem after first encountering Avira's inability to update new signatures. I downloaded a new version from CNET avira_antivir_personal_en.exe and executed it on top of the existing program.
It started and asked whether to repair or remove. I went for repair, and it continued posting an error. That did not work.
I executed the download again and asked to remove, which it did most thoroughly.
Then executed the same file again and it allowed me install avira without problem and naturally the missing file ccplg.xml was there.
All good
May 03, 2008 | Compaq Evo N610C Notebook
Open Questions:
See all NEC 90MHz P8 CPU (1580261940) Motherboard Questions
NEC 90MHz P8 CPU (1580261940) Motherboard Logo
50 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
