Question about Brother MFC 240C All-In-One InkJet Printer
Refilling ink Cartridges
I bought some refillable ink to refill my catridges, but I dont know how to refill it.
  • 3,866 Answers
There is a service hole on the cartridge that u need to unplug with a small drill bit or some type of hole puntch. Then u need to cover the hole with the stickers it came with..
Posted on Apr 23, 2009
Refilling procedure
You need to specify what brand is your printer.But the procedure is as simple as dirty. Make sure you have a cloth or paper to handle the messy part :).
Requirements: 1. Printer-Ink 2. Syringe with thin needle3. Piece of cloth
I will write how to refill HP cartridge, because I don't know your model.Ususally Hp cartridges have colored or black spot ont white sticker.Under this spot there is a tiny hole. This hole is designed to be used for refilling. You need to pierce the spot with the needle and start the refilling process.Make sure that there are no bubbles in the syringe and start filling slowly the cartridge. Do not hurry! Don't fill the cartridge to its full capacity. If your cartridge is 20ml fill only 15 or 16ml.After you finish set aside the cartridge for 30 minutes so that the ink settle. This is it!Good luck!
Dec 19, 2011 | Office Equipment & Supplies
Hi I bought a lexmark S405 and when my ink finished, i decided to refill the black catridge but the print wont print unless i buy a new catridge which is expensive than buying a new printer. I wanna...
The Lexmark S405 printer requires all cartridges to have ink in them to continue printing.
The 100/100XL cartridges are not licensed to be refilled. You can, however, refill the 100A or 100XLA cartridges available on the Lexmark website at http://www.lexmark.com. You should be aware that a refilled cartridge will not be able to report its ink level, and you might not get the print quality you expect from ink that is specially formulated by Lexmark to pass through microscopic nozzles at extremely high temperatures.
Sep 20, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Steps on how to refil my hp catridge
Refilling instruction vary between printer ink cartridges and you need to refer to the instruction in the ink refilling kits.
Mar 19, 2011 | HP DeskJet F380 All-In-One Printer
Canon JX 210 P Ink Level reset?
its not recommended to refill the cartridges as it causes problems!It recommend getting a geniune cart!
Apr 05, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Canon mp460 printer. refilled cartridge not recognised
Dear Sir,
This is deffinately due to catridge circuit problem.Canon suggest that we have to replace emptied catridges with new genuine canon catridge they dont suggest refilling and also not give any support for refilling catridges. So you can replace catridge with new one.
This Happens due to weakining of catridge circuit portion or may long period printer not in use.
If you not want to replace catridges i will give you the possible hints it may fix refilled catridges.
1.Clean the catridge circuit portion with soft cloth,care must be taken that there is no smudge or ink traces on catridge circuit.
2.Clean the ciruit of printer catridge placing box present inside the printer .wipe out the any sumdge or ink traces.
Then re install the catridges. give the print if it shows error press resume button continuosly. I think it will fix your problem.
If it is not solution is replace the catridge with new one.
good luck
Aug 26, 2009 | Office Equipment & Supplies
Printer do not recognise color catrige
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 13, 2009 | Lexmark X1240 All-In-One InkJet Printer
I need to know how to refill my ink in my printer
Hi lisa40447,
It really depends on the make and model of your printer. But I would strongly go against refilling the ink cartridge because there is a very big possibility that you can damage your printer if you keep reusing a cartridge that has used up its life. The big problem with this is that the ink usually leaks out or "bleed" when cartridges are refilled and in turn this damages components inside the printer.
It's still a better option to just buy new ink catridges for your printers, since it is more expensive if the printer gets damaged due to usage of refilled ink cartridges.
Hope this helps!
Peace! :)
Oct 20, 2008 | Computers & Internet
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Refilling ink tank
please donot use refilling system it is not for printer
it is new catridge after finishing you can refil for once dont use more times
it depends upon refilling-the quantity-before refilling you should clean with boiling water and then start refilling-if you shake the hands it ink will come out nozziles then use if not see the contacts of the catriges-if not just replace new catridge
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Installing print cartridges
refilling catridges is not advisable it is better always go for new one .bcoz the ink which is used for refilling it is not good which is damaged the print head and the the catridge nozzle . i will advise you to buy a new actridge and install . bye
Sep 21, 2007 | HP PSC 1210 All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
88 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
