Question about DVD & Blu-Ray Players
Portable dvd player dark screen
I have this memorex dvd player it plays and sounds fine, I can see the picture but it is dark. Could it possibly be that the backlight is out? or something else?
SOURCE: portable dvd player - wont play
Bought a dvd laser lens cleaner for 10 euro played it through the dvd player a couple of times and its working great now
Posted on Apr 10, 2008
  • 140 Answers
SOURCE: cracked screen memorex portable dvd player
It is unfortunate that the screen cracked and that your particular model can be found on the internet for nearly what it would cost you to get it serviced if you could get it serviced in a timely manner. For instance there is a Memorex MVDP1078 Player for $114.00 at A tv repair shop would charge you almost that amount if they can even get the part. If you send it in to memorex you will also be disappointed at how long and how much their out of warranty work costs. Since it is your friend, I would suggest you replace it and tell them what happened. As long as everyone is happy the question of getting a brand new one or getting it fixed should not be a problem. Good luck and God bless.
Posted on Jan 22, 2009
  • 320 Answers
SOURCE: I have sound but no picture on my portable DVD player.
yes it can be fixed.replace the capacitor c564 and c513 on the main circuit board to bring the picture back as this capacitors gets over heated and cause this problem.
Posted on Mar 06, 2009
  • 814 Answers
SOURCE: my portable dvd player has sound but no picture on the screen. pl
If you still have use of the on screen menu functions, you can try using the restore to factory setting option in the preferences section of the set-up menu. Press the setup button on the remote control and use the up and down arrows to find and highlight the preferences section, press ok to enter the sub-menu.In the sub-menu use the up and down arrows to find and highlight the default option. Press ok. This will reset the dvd player to the factory settings. If you do not have the use of the on screen menu, you can use the a/v outputs to a external monitor or television to perform the abouve procedure to try to restore the dvd player to normal operation. If all this fails you can call Phillips customer support at this telephone number. 1-888-744-5477 They will be able to help you, either solve your problem or get the dvd player serviced.I hope this information helps you with your problem.
Posted on May 31, 2009
SOURCE: does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Posted on Jun 19, 2009
  • 80 Answers
SOURCE: RCA DRC6338 screen is dark
There can be dead lamp or invertor. Give it for some special guy who can fix this.
Posted on Aug 08, 2009
0 characters
1 Points
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
Memorex mvdp 1085 dvd player, says door open.
our memorex 1085 doesnt play it just buzzes and has a blue screen
Jan 09, 2010 | Memorex DVD & Blu-Ray Players
My Phillips DVD player has a white screen. It will play the DVD but still show white screen.
The wire could be loose that connects the screen to the dvd player board, these are a common problem on alot of portable dvd players.
Aug 10, 2009 | Philips PET702 Portable DVD Player
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
Portable dvd player problems help!
It appears that the connectivity or processing for display is the culprit. Please refer to our experts to solve the problem.
Sep 10, 2008 | RCA DRC635N Portable DVD Player
GPX PDL705---Picture very dark
Sounds like the back lighting of the LCD screen is faulty. Is it a new unit - take it back. You might try the brightness and contrast controls and turn them up. If that doesn't help it needs to be repaired.
Sep 09, 2008 | GPX PDL805 Portable DVD Player
7" tft monitor portable dvd player
I have 8.5" TFT widescreen Monitor Portable for three years. Now when I turn it on, it only has sound, the picture only has one second blink, then dark.
I am now in Shanghai,China, is there a service in Shanghai which I can go physically to get it repaired?
Jul 13, 2008 | Mintek 8.5" Portable DVD/CD Player
make sure clamshell open switch is up, its a little tit that is in front of the DVD door and off to the right, it turns the screen on when the clam shell is open.
Jan 20, 2008 | Protron 7" Portable DVD Player
DVD & Blu-Ray Players Logo
157 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
