Question about Whirlpool Duet GHW9150P Front Load Washer
Problem with operation of front load washer
My whirlpool front load washer won't cycle. the door automatically unlocks after about 2-5 minutes of operation. The water does not drain...like it won't spin.
    Sergeant:
    Champion:
  • 262 Answers
Chance are you have a clogged pump follow take front lower panel off screws near the floor on the pump is a slit open the slit on the pump and you will see the filter if it is clean follow the next instructions.
take the front lower cover off and there is a tech sheet in there look at it and it will tell ya what the code is for and how to correct it I cant remember this code off the top of my head and all the brands have different codes.I have about 5 three ring binders of tech sheets in my van if you cant find it i will look it up for you once you find this sheet clear the code and run it through diag.mode the sheet will tell you how to put in in self or automatic try auto. good luck.for get the code thing i just answered a code question but run it through this test to see if unit is working ok other wise
Posted on Dec 22, 2007
SOURCE:
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Duet GHW9150P Front Load Washer: HOW DO I UNLOCK MY WASHER...
    Depress the "end of cycle" button on your panel for 3 seconds, wait for 2 minutes, try the door. This is the child lock feature, do it again and it locks.
    Pl vote me nice, for the free help, thnks.
    May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9150P Front Load Washer: how do you unlock the control when it is locked...
    While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
    Check your washer plug to see if the connections are tightly screwed.
    How abt a nice rating for the free help? Thnks
    May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Door will not unlock on my whirlpool washer wfw9200sqa
    Power must be on. Hold down the 'end of cycle' button at the right side of the panel for 3 seconds. Wait for 2 minutes then try the door.
    Mar 22, 2009 | Whirlpool WFW9200S Front Load Washer
    Washer will not reset
    Depress "end of cycle" button for 3 seconds & wait for 2 minutes to try the door gently.
    Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Canceled the clean washer cycle, got "INT", won't work now
    Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
    Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    78 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
