Question about Sony KP-53HS10 TV
THE 3 COLOR LIGHTS DO NOT ALIGN
IT IS MOSTLY THE BLUE LAMP AUTO FOCUS BUTTON DOES NOT SEEM TO REALIGN IS THERE A WAY TO ADJUST WITHOUT SERVICE
  • sprocket1 Dec 15, 2007
    Is there a manual realignment for the guns if the auto alignment circiutry does not work?
    Genius:
  • 1,694 Answers
No....needs convergence circuit repair.Usually several hundred
dollars to change out convergence IC's..................T.
Please rate this solution.......................
Posted on Nov 13, 2007
SOURCE:
Picture is unclear color are off
there are a few things you might be able to do. First I would try the auto focus or alignment feature of the set. there should be a option in menu to realign the lamps.
May 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Rca hdtv rear projectiontv.how to adjust focus
You will want to use a funtion called either convergence or auto convergence. It realigns the 3 colors to the correct possition on the screen.
Feb 28, 2010 | RCA R52WH76 Television
Replaced lamp in lg ru-44sz61d dlp picture blue
This TV has no guns. It has a lamp and a color wheel.
Owner reported model number as: lg ru-44sz61d dlp. Pay particular attention to the "dlp" part.
I do not know what is causing the issue unfortunately.
Jan 10, 2009 | LG RU-44SZ61D 44" TV
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Color alignment problem
You will need to put the unit into wahts called service mode because it will have to totally realigned since you change the whole module you changed the chip that had you stored memory setting for convergence called an EEPROM. here in the shop I would unsolder the old EEPROM and put it on the new BOARD. Also on most models you don't have adjustments for the green you have to move red and blue to match green. Imay want you to describe again to me what you can adjust now with the new board in the unit can you move all colors left right and up/down
Mar 10, 2008 | Samsung HCM4215W 42" Rear Projection...
Colour misalignment and focus
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Feb 17, 2008 | Office Equipment & Supplies
Samsung rear projection tv has multiple images with differnet colors
The auto self focus screws up if the picture does not remain constant or close to it while focusing. It is designed to self focus every fifteen minutes. Go to menu and then setup and turn the auto focus feature off. I have had mine off for the past year and have had no problems. If you slide the bottom portion of the remote down you will see a self focus button. My suggestion is to put a DVD in and hit the pause button during a scene and then hit the self focus button. It should align back up and may take a couple of tries. (If you have an aftermarket remote, just enter the menu and then setup and you can activate the self focus feature, just don't turn it to auto focus!)
Dec 31, 2007 | Samsung HC-P4752W 47" Rear Projection...
COLOR LAMP ALIGNMENT
Needs convergence circuit repair...........
Requires replacement of soldered-in parts..............T.
Sep 24, 2007 | Sony KP-53HS10 TV
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Conversion problem
Has it been moved latley? is there any auto align mode? i know the lenses can bounce inside there during a move and it can throw off the focus. If there is no kind of auto align it may need serviced. Usualy they have to come out and realign it using special tools. The tools display a cross on the screen in each color and they adjust the throw of the guns that refocus all the colors to the center till it becomes one solid color. The panel drops down from the fron and you adjust the pots with a plastic tool that realigns the guns. There may be a mode in the settings to display the image you use for the alignment. This is a common thing and i think they recomend it be setup at the home and not moved after its setup.
Apr 04, 2006 | RCA P46812BL 46" Rear Projection...
Sony KP-53HS10 TV Logo
308 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
