Panasonic PT-56WX33G HD Rear Projection TV
I also have a convergence issue, but I have looked inside for the Convergence Ic's and can't seem to identify them, in my case, it's the red that is off. I saw a module labeled as a13266 and I thought that was the module, but can't confirm. I was wondering if i am looking at the right part, or if If these IC's would under something or where they are?
  • leo_07663 Dec 11, 2007
    This is in regard to this specific issue, I replaced the convergence IC's and that fixed my issue completely, I am enjoying a clear picture, and great sound now...
SOURCE:
SOURCE: Where can I get parts?
STK392-110=CONVERGENCE IC USE TWO FOR REPLACECEMENT PART= WWW.bdent.com Product Details: The STK392-110 is a convergence correction circuit IC for video projectors. It incorporates three output amplifiers in a single package, making possible the construction of CRT horizontal and vertical convergence correction output circuits for each of the RGB colors using ust two hybrid ICs. The output circuit use a class-B configuration, in comparison with the STK392-010, realizing a more compact package and lower cost. www.partstore.com
Posted on Jun 04, 2007
SOURCE: CONVERGENCE ic CHIP
I replaced the Convergence IC Chip STK392-110 for my PT-53WX42 Panasonic HD Rear Projection TV but I found burnt resistor(resistor #)R7053,R7002 & R7005.Can someone tell me the part# ,description,resistor value and power rating.I don't have the schematic to look .Thanks
Posted on Sep 08, 2007
Slinteriors
  • 8617 Answers
SOURCE: Red shadow on PT-56WX33G projection tv
The cheapest way is to replace both convergence Ics they are both STK392-110 and you can get replacements at the following link, and they provide free instalation instructions with pictures, plus free online instant messageing while you do the actual repair. Its a very easy repair. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jul 27, 2008
SOURCE: where to buy a convergence ic
This link may help you with the convergence problem: http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
You can just put the search "convergence ic" into EBay and get a list of sellers for the ic's.
Posted on Aug 24, 2008
SOURCE: JVC AV48WP30 convergence ic
I'm in the process of trying to replace both convergence IC's in my JVC also. I was able to buy both IC's (they look like black semi-rectangular components with 20 pins sticking out...like a computer chip only much bigger) at a TV repair shop for about $15 each. They were clearly labed STK392-110 (but could be 150 or 180 if you wanted to upgrade).
Posted on Mar 29, 2009
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
Sony KP-41T65 41" rear projection tv with convergence issues on part of the screen. And screen is generally slightly blurry. I received this TV already broken (had the red blinking light issue) which I...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-41T65 41" Rear Projection...
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
Toshiba 43VJ22P convergence trouble! I have a Toshiba 43VJ22P, the red convergence was out in the x plane, and could not be adjusted, however it could be adjusted in the y plane. So i've changed the...
Hi
Thanks for using FixYa. Then it means the problem is with the convergence board and it’ll require to be replaced to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 26, 2010 | Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Panasonic 53" tv pt-53wx42
your convergence ic is going bad. remove front and adjust the level of blue.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence Problem
Replace the Convergence Ics and the six 2.2 ohm resistors. Heres a link to the proper repair kit for your model which contains both Ics and the resistors plus step by step instructions with pics on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 06, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-60LC14 Convergence Issue
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 06, 2008 | Panasonic PT-60LC14 60" Rear Projection...
Thought I had a convergence problem - red is still broke
KCOZI,
I dont think you have problem with Red Gun.
One of your Convergence IC is faulty with 2 RK series Resisitor(Low Value) in Convergence
Amp Borad.If you changed IC look for RK series Resistor (may be 3.9ohm/2.7ohm)
Dont forget to Rate!
Good Luck
Dals123
Oct 21, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergence STK ic parts?
Yes your set uses two STK392-110 convergence ICs you can get replacment ICs at the following link with free instalation instructions.
Aug 06, 2008 | Toshiba 57H82 57" Rear Projection...
Televison & Video Logo
697 people viewed this question
Top Televison & Video Experts
Ekse
