Question about Kenmore Kitchen Ranges
Kenmore Electric Oven door (3.5 year old unit) will not seal. Is there adjustment or replace hinges or what?
  • 135 Answers
Wot?
You can't buy a new oven???
LMFAO!
Electric, at the VERY LEAST!
What a LOSER!
Posted on Feb 17, 2010
  • ted dux Jul 11, 2012
    delete
Oven door on F@P oven not sealing
Check seal on door, and then see if your hinges are adjustable,
May 30, 2014 | Fisher Paykel Fisher & Paykel OB24SDPX1...
I have a Competence B 6139-4-m electric oven. the door does not close properly, have tried cleaning it as intruction manual suggests, the heat escaping from the oven has scorched my cupboards
the fault is unlikely to be the actual oven unit so therefore in order of least expense the things to check are:- the door seal being complete, the hinges not having been forced, the door not being buckled, self adhesive universal seals are available online from *spares etc. Hinges are easy to remove from the cooker and then can be unscrewed from the door and replaced. if it's the door I would have to say that's less likely to be available for a sensible price.
Feb 05, 2013 | AEG B1180-4 Electric Single Oven
ECD230 dacor oven, th bottom door isn't sealing all the way, you can feel heat escaping. Is there an adjustment to make?
jenn air had some issues with there hinges wearing fast in prior years on there ovens and then you have the ones the kids use as a trampoline sometimes or the heavy turkeys laying on the door while it is opened... there really isn't any adjustment for the door the hinges bolt inside and are held in one place by a few screws ...they are replaceable as welll as the door gasket on the unit... hope this helps you out some... alot of the appliance sites out there will be able to assist you with parts such as www.sears.com then click the parts direct link up top have your model number usually inside unit either on door or inside where door closes... some units between door and cabinet area... good luck to you
Jan 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
Freezer door does not close tightly.
You can try replacing the seals and or adjusting the hinges.
That may work.
Be aware that if the unit is over 10 years old it is probably using twice as much power as a new one would and costing you an extra $75 to $100 annually to run over a new unit. Could be more than that if the door seals are not tight as well.
Jan 01, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Oven door won't close tightly
Sounds like whoever installed your oven hasn't adjusted your door properly and as a result over time probley got worse? any way there should be 3 screws on each hinge the top and bottom screws hold the door in place the screws under the top ones are used for making adjustment with a Philips head screw driver open the door and try screwing in clockwise 2 or 3 full turns and with your free hand feel if the door is moving upward if so repeat the same on the other side and then close the door and see if its made a difference if so and its still loose try again if its made it worse the turn the screws in the opposite direction Let me know if this works
Dec 09, 2017 | Whirlpool RBS305PD Electric Single Oven
Oven Doors will not stay closed all the way
I think this is a cheapest and eat way to fix your oven doors... Otherwise there are 2 spring type locks of the door that starts getting old day by day ... You have to change the pair of lock only
Apr 05, 2008 | KitchenAid Architect® KEBS277S Electric...
Oven door hinge adjustment...?
Regarding the oven door not closing all the way and dropping suddernly to the floor, I called a local authorized service company and asked if there was a door spring (no). So the recommended solution is to have the hinges replaced. However, since the oven door didn't really hold its open position from the beginning, when it was brand new back in 01, I'm going to see if a new Viking oven has the same defect as ours. Then, it would seem like a good idea to take a chance on having it repaired.
Is replacing a set of oven door hinges something a person with reasonable mechanical aptitude can do?
Nov 24, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Kitchen Ranges Logo
103 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
