Question about Broan-NuTone Allure III QS330SS Kitchen Hood
Lights won't turn off - everything else works fine
Lightblub blew out and now lights will not turn off - even after replacing blown lightbulb. Only way to turn off lights is to now unplug the entire unit. Fan seems to work fine.
  • kkrj Apr 24, 2009
    Talked to Broan technical support and they said I needed a new control board that I can install myself. $210 later.......
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Posted on May 01, 2009
1993 Dodge B250 Ram Van (Conversion) -- I have no rear running lights. The brake lights, turn signal lights and hazards all work fine. While driving through rain, I hit a big puddle. Some time later...
something in the wire setup has gottn wet and caused it to short out . i would recomend ordering a new wiring harness for the engine compartment. and when re connection everything use di eletcritc grease in them so they will not do it again.
Oct 07, 2013 | Cars & Trucks
I have a 2004 Nissan Maxima and my tail lights dont work and whn my headlights are on the dash dimmer doesnt work and a section up by the radio lights dont work. I checked my fuses and the headlight fuse...
find the short, could be in the switch or a wire itself...and if you have a bulb out it complicates finding it even morenew fuse it, then turn things back on one at a time...should tell u where the problem is
Apr 06, 2013 | 2004 Nissan Maxima
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
93 camry I was replacing a defected brakelight bulb and when I was removing it it made like a short and after that all 4 of the brake ligths don't work. Checked the fuse its fine every other lights work...
It is more than likely that when you heard and or saw the short it remained shorted thus taking down everything on that particular circuit. It should have blown the fuse but if in the past the fuse blew and replaced with a too high a current rating it would not blow the fuse. Go back to the original bulb location remove the bulb and try the brake lights again. If you are working alone, pound aut a weight on the brake pedle and remove the bulb, move the wires around and watch to see if at some point the other bulbs lights go on. You will then be able to more accuratly isolate the short location. Good luck
Sep 27, 2010 | Toyota Camry Cars & Trucks
Where to start looking for a short in a 1992 ford ranger. keeps blowing the fuse that runs the dash lights and the tail lights ..first it blew .i replaced .was fine till next night .turned on lights...
connector under the truck, near the trans
cannot remember specifics at this time but remember starting there every time one cam into the dealer with tail light issues and blown fuses
Jun 17, 2010 | 1992 Ford Ranger
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Broan-NuTone Allure III QS330SS Kitchen Hood Logo
1,130 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Phil Lovisek
Phil Lovisek
Steve
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
