No sound from Pioneer A 757 stereo amp.
I am getting no sound from my Pioneer A 757 stereo amplifier. It works intermittently, but now, nothing. It powers up, but there is no hum in the speakers.
5 Suggested Answers
SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: Pioneer Stereo amplifier SA-7800 sound problem
reach me at my email snhaqua@hotmail.com for to fix pioneer amplifier 7800
Posted on Sep 11, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
  • 979 Answers
SOURCE: PIONEER VSX-9700S
Speakers must be selected on the front panel of the rcver, and tape ll monitor must be "off", or at least have an outboard processor attached to the tape ll loop. "A" or "B" doesn't matter, but one must be selected to hear program material. If all connections are correct and it still won't work, consider that the output stage has failed....accordianman
Posted on Feb 24, 2009
Getting humming sound from amp, replaced rca cables, made sure the ground was clean, tried friends amp also. Pioneer 700bt. Any suggestions?
Check the ground on the battery and the engine for proper conection. Cheap brand stereo also causes engine noise
Jun 04, 2015 | Pioneer Car Audio & Video
Radio quit, no sound no LCD display no clock display, antenna doesn't raise
Sounds like the 12v constant wire is dead, usually the yellow wire connected to the radio. Check for correct voltages.
Oct 02, 2013 | Pioneer 1990-94 Lexus Ls400 Stereo Radio...
Amp 2400 watt sub woofer
Use this link and print it up and take it to a local car stereo shop to get ideas, then shop for it the way you want .http://reviews.cnet.com/car-amplifiers/pioneer-gm-x924-car/4505-6726_7-30233385.html
Their not bad amps but don't exspect a lot.
Sep 24, 2013 | Pioneer GM-X924 Car Audio Amplifier
I have a pioneer car stereo after a battery switch my amp gets power, but my subwoofers don't work
is the light on the amplifier on. is your remote wire the blue wire with power. if not you have a remote problem but if it all works check your rca's on the radio or your amplifier.
Jul 29, 2009 | Pioneer DEH-P690UB CD Player
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Radio comes on but i cant hear any music
You may be connecting this stereo into an amplified system. If the original factory stereo worked with the factory amplifier, your stereo is not turning the amplifier on. If you purchased the aftermarket wire harness that mates to the factory stereo connector, hook up the "Amplifier Trigger" wire, this wire is usually blue.
Oct 16, 2008 | Pioneer DEH-P3500 CD Player
How do I install my pioneer stereo?
this way should work : connect the OUTPUT of stereo ( ke-4535) to the INPUTS of GRAPHIC EQUALIZER ,then the speaker outputs of the GRAPHIC EQUALIZER to speakers , in this order you have control to adjust the sound coming from the PIONEER stereo . hope this helps
Apr 25, 2008 | Car Audio & Video
Connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
Oct 28, 2007 | Audio Players & Recorders
437 people viewed this question
 Grubhead
Grubhead
