Question about Panasonic DVD-RV31 DVD Player
DVD-RV21 The DVD's can not be read by the DVD player and the code H02 error code keeps coming up. How do I fix this?
  • Anonymous Dec 14, 2007
    when i put the disc in it reading and then it say ho2
SOURCE: Error H02
I had the same problem and found that the motor that spins the cd so it can be read would start and stop. I opened the case removed the assembly with the motor and placed a drop of 3in1 lightweight oil on the shaft of the motor ran it a few times and now it works perfectly fine. Good luck hope this helps you as well.
Posted on Dec 24, 2007
t0pc4t
  • 132 Answers
SOURCE: PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Posted on Aug 15, 2008
TheQueue
SOURCE: panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Posted on May 05, 2009
satavlad
  • 405 Answers
SOURCE: ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Posted on Dec 01, 2009
SOURCE: error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Posted on Jan 19, 2010
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Problem playing dvd with panasonic sa-pt660 keep getting an H02 error message?
Thousands of annoyed customers of Panasonic, Yamaha, and Denon DVD Player owners have encountered the infamous H02 / H07 /H03 erors and many others on thier players or maybe the "No disk" error even though a disk is in the drive. Well many people have spent hundreds on repair or bought a new unit. But i am here to tell you that it is okay to open up your dvd player and mess around in side. If your DVD player comes up with one of these errors the first thing you might want to try is to open up your DVD player by removing the screws on the side and the back (depending on the model), then plug the dvd player into power outlet with cover removed. Stick a disk in and press play and give the disk a little push. Most of the time the Spindle motor is dieing out when you get a H02 error. In this case that little push may get your spindle motor to rev back up back into action. And if your as succesful as me then hopefully you have just fixed your H02 error for free without doing much work. I just got a Panasonic HT95 Reciever/DVD player to play all disks again by giving the motor a little "kick start"
Jan 05, 2011 | Panasonic Televison & Video
Dvd will not play. H02 appears. Have reset to no
H02 is a fault code, though I don't know what. It code be either an electrical fault or mechanical problem. A mechanical fault might be easy to spot so take off the top cover and see if anything is broken, otherwise I suggest a service manual will come in handy.
May 21, 2010 | Denon DVD-800 DVD Player
Error H02 for panasonic dvd s35
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
ERROR H02
Dec 01, 2009 | Panasonic Televison & Video
PANASONIC SA-HT800V
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Jul 10, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
PANASONIC SA-HT800V
servo problems will need to replace dvd board...is that cost effective ?..replacement price??
Jun 13, 2008 | Panasonic sa-ht800V Home Theater Audio...
Panasonic DVD-RP56 Error H02
Feb 10, 2008 | Panasonic DVD-RP56 DVD Player
Error H02
Dec 21, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
Panasonic DVD-RV31 DVD Player Logo
166 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
