Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Got tv from friend
Hi my name is mike. Just got the tv from friend tv turns on and green light stay on. picture has a green line and can barely see the menu. try to see if its worth fixing.
  • Mitsubishi Master
  • 3,866 Answers
Try and see if you can autoconverge the green if not you going to need to get it serviced manually. thanks
Posted on Apr 23, 2009
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Hi, i have a PS3 60G, turned it on, was working fine, played around with the sidplay to HDMI and themes, then the picture was destorted, switched off at main power switch on back, switched it back on, my...
You have it on the wrong TV setting you need to work out how to get to the tv setting BLIND then change it back to default!! I have had same problem wioth a friends but managed to change it without the screen back to default and now its ok.
Aug 13, 2010 | Video Game Consoles & Games
My sharp tv wont stay on, it flashes green
Hi i have seen this before sharp hdtv's are known for having the internal power supply go faulty
Feb 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36 inch 36v430t
It's simply refered to as the power supply- the repair guys will know exactly what you are talking about when you use it. You see the power supply upgrades the power to drive the tube- much in the same way a coil increases the power on your car from 12 volts to what ever it needs to turn the engine. The green light just means that you turned it on, and all the other curicuts are working. Like if your car coil is bad-you can still turn on the lights and radio-but there is not enough power to turn over the engine/turn on the picture tube. I love my 36 incher- mine is 12 years old-and was only in the shop once-and still gives a better picture than the LCDs out there. I'm a member of SMPTE. society of motion picture and television enginers.
Jul 02, 2008 | RCA F36650 36" TV
Help me willtab guru man...Please.
What is the make and model of your television.. green tint and vertical lines indicat a problem with the light engine..although the clear menu says otherwise..im not sure what type tv you have. lcd plasma change the light im guessing you mean bulb .. this indicates to me you have a dlp. but green tint to me indicates a tube projection type tv... so im just guessing hear. vertical lines also indicate a bad buffer board on a plasma or lcd. so let me know what you have
Jun 16, 2008 | Televison & Video
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
