Question about Manitowoc MAN-KF6E Koolaire Undercounter Freezer Reach In One Section 6in Adjustable Legs
How Do I maintenance a manitowoc series 150 ice machine
It stops making ice for periods of times but I do not know how to clean it well. Can you help me please?
    President:
  • 3,074 Answers
Find the filter remove clean with water, coils should be shiney. This should fix the problem
Posted on Jul 23, 2010
The machine will make a couple of cycles of ice then stop. If i turn it off to clean then turn it on it will work for a few more times but then stop again. Any ideas?
Sounds like the bin switch. If it stays in the open position then the machine thinks it is full of ice and go to automatic shut down.
Sep 19, 2015 | Manitowoc Ice Machine QD-0212A Air Cooled...
Icemaker runs constantly but never makes enough ice to shot off. Too much water spraying out and melting the ice. What to do? Have run through cleaner cycle several times. Disassembled and cleaned also.
Process of elimination. ... ice thickness sensor (adjust and clean).... water outlet bar with holes that runs down the ice maker plate (make sure all the holes are not clogged and point to correct angle to keep from splashing) check those 1st.. the other steps are more involve if you have refrigeration tools to check refrigerate level, etc.. let me know if this will help 1st
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
What causes the manitowoc ice machine to cut off during the freeze cycle
most of the problems on ice machines is a restriction in water circulation due to no maintenance. Might need some cleaning to be done.
Apr 19, 2013 | Manitowoc SY0854A Self Contained 870 lb...
My ice machine manitowoc q 132a starts up stops after few seconds while water pump start
There is a high pressure switch that stops the unit running if a fan fails or the condenser is clogged. Next time you start the ice machine, watch the bottom led on the pcb. It will tell you if there is a fault. Meantime, reset the hp switch and clean the condenser thoroughly.
Sep 06, 2012 | Refrigerators
Manitowac Series 150, not producing much ice, cycles itself off.
Use a fan to try helping it stay cooler but make sure coils are clean and refrigerant is not low if it has a temp setting turn it down
Nov 06, 2009 | Manitowoc MAN-KF3 Koolaire Freezer reach...
Manitowoc 210 ice maker
The thickness control (Im not sure if its like the bigger models) isa plastic piece that has 1 or 2 metal prongs that as the ise is frozen to the evap plate the water trickels closer to these probes. eventually commin gin to contact with the probe and allowing the board to "see" that the ise is ready for harvest. Perhaps this is set too close?
Or the machine may need a good cleaning. DO NOT USE LIMEAWAY on manitowoc. It has a nickle coating on the evap plate and the cleaner has to have inhibitors in it to keep the nickle plating from flaking off.
From your genmeral information these are a general idea of the 1st 2 things that can cause your problem.
Please ratem me as high as you can and let me know if you have tried anything and the results or if you have more information to add.
Mar 29, 2009 | Manitowoc Koolaire Undercounter Freezer...
Manitowoc MAN-KF6E Koolaire Undercounter Freezer Reach In One Section 6in Adjustable Legs Logo
994 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
