Question about Panasonic Palmcorder PV-GS12 Mini DV Digital Camcorder
Panasonic pv-gs12 reset
My GS12 ask me to push the reset button more and more often. It has reached the point that I can not even use it. PLEASE HELP ME
  • 7 more comments
  • rmoore85 Sep 27, 2007
    thanx for the info. How did u correct the problem??
  • shippi Nov 05, 2007
    I am facing the same problem.. and its very annoying. What is the solution for this issue. I dont want to buy a new camcorder as i had bought this just 2 yrs back
  • Ivanchamorro Nov 13, 2007
    I Have to push the reset button more and more often. It has reached the point that I can not even use it because the where gone the videocasset is opened and no close. PLEASE HELP ME
  • claybaby Dec 18, 2007
    yes i have same problem reset reset and it does not play back
  • jel10 Dec 23, 2007
    Mine does the same thing, but at also says that there isnt a tape inserted when there is
  • jasonmayer Jan 02, 2008
    Same problem here - keeps asking me to Press the Reset Button. When I open the tape door it does not pop up. The tape is stuck in it. Happened just after my kid hooked it up to his computer trying to use webcam feature. Bad timing, or did this have something to do with it?
  • beachjay24 May 31, 2008
    yes same problem and blue lines too man mine is really screwed up
  • dneuten Jun 07, 2008
    Cassette tape can't pop up. it keep asking me to reset. I did reset but not work
  • Anonymous Oct 27, 2008
    The 'press reset' indicator prevents me from using the recorder. No matter how many times I press it, the item seldom works. Spontaneity is non-existent.
I have had all of the same problems, and I even asked my digital video professor and he couldnt figure it out. I had pretty much given up, but i used a head cleaning tape for the blue lines, and the reset button i just kept pushing it turning the video camera on n off, and taking the battery out until the tape came out , and eventually just blew in it, and right now its working again, hopefully that helps some of you...
Posted on Apr 07, 2009
I have the same problem, but when i took out my batter, put it back in and took out my tape..the reset button errors stopped..i think my tape was bad..i tried a new tape and i dont get those errors..now i just get the blue lines..when those blue lines are gone itll work now..
Posted on Sep 25, 2008
I tried it but did not work. Any suggestion
Posted on Jun 07, 2008
Take the battery and/or any power sources. When it is turned off with no power, press the reset button momenterily. I hope this helps.
Posted on Jan 02, 2008
    Problem Solver:
  • 18 Answers
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Posted on Feb 04, 2009
Same problem
if still bars head must be replaced
Sep 11, 2009 | Panasonic Palmcorder PV-GS12 Mini DV...
Tip
I have trouble with my PV-GS12
Buy my PV-GS12 but I came with no driver and I can not get it from any side. The driver that I would help to lower engraved on the tape to my PC. Someone may tell me to do or where to get the driver.
on Mar 25, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Need assistance transferring video to imac
The Panasonic PV-GS12 will transfer video in video record mode and video playback mode using the DV connection (IEEE) Firewire port. PC Mode is restricted to memory card access via USB. If after connecting it in this manner if it does not work try this. With everything connected via firewire and iMovie running. switch the camera to PC mode and the import window should pop up. You may get a comunications error and if you do then switch to playback mode. The import window should stay open and you can control your camera with the iMovie controls.
Jun 01, 2009 | Computers & Internet
Panasonic camcorder dv
This problem is in the owners manual. It says that if you press reset and the problem keeps recurring you must have it serviced. Per the panasonic website if you purchased the camcorder greater than 1 year ago the flat fee for repair is about $265. Buy a new camcorder, thats the most cost effective solution.
Oct 16, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Tape don't pop up
a reset error is not repairable if you do not have exsperience with this. If this unit is showing a reset error there is either a fault with the lens or the tape mech, looking at your fault the mech is faulty and only a qualified panasonic technician is going to be able to repair this.
Jun 13, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic Palmcorder PV-43 turns off with a tape inside
you definetly have a tape mech fault and this is going to have to go for repairs to panasonic.
Apr 25, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Video Removal
you need to installed a driver.... ...try this web www.driverguide.com
Mar 11, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic Camcorder
Open the side door where the video scren is, and it's a tiny little gray button you have to push in with a pencil or pen all the way on top, above the soft skin and multi/p-in-p button!
Jan 19, 2008 | Panasonic Palmcorder PV-GS12 Mini DV...
Blue bars across video
I have the same problem with my PV-GS14. You have to find the last spot you recorded in, pause it, then switch to record, and just record something for a couple of seconds. Switch back to playback, and it should be fine. Neonlaundry, I read your other posts, and it seems we both have the same problems. If you find a solution, please post it. Thnks.
Mar 13, 2007 | Panasonic Palmcorder PV-GS12 Mini DV...
Panasonic Palmcorder PV-GS12 Mini DV Digital Camcorder Logo
1,245 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
