Question about Maytag PAV2300 Top Load Washer
Washer jerks like hell when on spin cycle - Maytag PAV2300 Top Load Washer
How much too have a belt replaced all cost
Posted on May 14, 2009
    Genius:
  • 1,198 Answers
Make sure it is not overloaded, or having trouble with loads like sneakers or carpets that will not spread out evenly. Check the outer tub from below or whatever to make sure all the springs are ok.
Posted on May 04, 2009
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
No spin cycle
Did you check to see if there is a broken
belt present
Dec 04, 2007 | Frigidaire GLTR1670A Front Load Washer
Admiral washer thumps after spin
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Washer jerks after spin cycle
most of the time your brake pads are worn down. the pads are glued on the rotor so when they are worn the spot of glue grabs the tub and stops it quickly.instead of the pads slowing it down.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 23, 2010 | KitchenAid KAWS700L Top Load Washer
As soon as the final spin cycle concludes..there is a loud clunk
make sure your laundry is evenly spread around tub when loading; most portables don't have self leveling features
Sep 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
H3 Elite front loading washer doesn't spin with small load
you have a clog in the hose or water pump some material got past the drum and made its way into pump or hose check hose make sure its not kinked behind the washer this could be whats wrong
or the door switch is bad
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
WASHER WILL START TO SPIN BUT THEN STOP
there is a motor kit to replace the motor on your washer. it the new style motor does solve the problem but it is expensive considering the cost of the washer itself
Nov 25, 2007 | GE WBSR3140DW Top Load Washer
Maytag PAV2300 Top Load Washer Logo
148 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
