Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Freezer not defrosting
My top-freezer Whirlpool refrigerator is no longer ''frost-free''. There is a thick layer of ice on the floor of the freezer. I chip it off, it comes back. I tried manually defrosting it, and it was ok for a couple of days and then a new layer of ice formed. The temperature of both the freezer and Fridge are fine. I have both set to the mid-setting. The door gaskets appear to be fine.
  • 2 more comments
  • krysiak Apr 23, 2009
    It has an icemaker, but it has never been hooked up to water. I am old fashioned and use trays.
    ET1CHMXKQ03
    thanks for helping!
  • steve
    steve May 11, 2010
    What is tour model number?
  • steve
    steve May 11, 2010
    Do you have an icemaker installed?
    Is it leaking water?
  • Whirlpool Master
  • 3,361 Answers
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Posted on Apr 23, 2009
SOURCE:
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
First the refrigerator portion lost cooling but the freezer was fine over time the freezer esentially turned into a refrigerator. It is no longer making ice or keeping things frozen, but is about as cool...
the evaporator coil is frozen over and cant release cold air due to this,defrost the unit remove rear panel inside freezer and troubleshoot the defrost heater and thermostat and also make sure the fan near this coil is running, on the evaporator coil as,you cant blow cold air thru a coil covered by ice
Jul 02, 2011 | Jenn-Air JSD2789GES Side by Side...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 24, 2009 | Whirlpool GS5SHAXN Side by Side...
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Thin layer of ice on the floor of my whirlpool top mounted freeze
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 12, 2009 | Whirlpool ER2MHKXPL 22.0 Cu. Ft. Freezer...
Ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Aug 10, 2007 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
351 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
