Question about Magic Chef 31000 Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Magic chef gas stove 1996 model 3127WTV. On my from burner the flames come out from under the burner. I am wondering if there is a gasket missing or if I need to replace the whole burner unit.
  • Magic Chef Master
  • 3,361 Answers
Replace the burner. Quickly. Do not use that burner until it is replaced.
Posted on Apr 23, 2009
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
My stove does not ignite even when glow light is on model 3127wtv
Turn off the gas supply to the range. Remove the oven racks,oven base pan,flame spreader.
Place a clamp on amp meter on one wire of the ignitor and turn the oven on to BAKE. When the ignitor glows it should read more than 3 amps. If it reads 3 amps or less replace the ignitor.
Jan 03, 2010 | Magic Chef Ovens
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
i searched and never got one . so my solution is not to use the stove and be creative how i make suppers. so that is how i fixed it. do without and go on.
Jan 14, 2009 | Magic Chef CGR1420 Gas Kitchen Range
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Magic Chef 31000 Gas Kitchen Range Logo
633 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
