Question about Maytag MDB7100AWB Dishwasher
Maytag dishwasher mdb7601 will not run-
The dishwash does not appear to have power. I checked the power supply from the house and the dishwasher has power. I would like to check the door switch next but I do not know how to proceed.
  • 4 Answers
If power to the dishwasher is OK, then the door latch may be the problem. You need to unplug the unit, remove the inside cover to the door and check the door latch switches (may be a pair) with an ohm meter for continuity. Each switch is a make/break connection. If that is OK, the problem could be a power connector to the control circuit board that could be loose.
Posted on May 07, 2009
How do I change or clean the filter on my Lamona 8362 dishwasher ? I do not appear to have been given a user manual Thanks
  • 1 Wait until the dishwasher has completely cooled after use before attempting to clean the filter. Turn the dishwasher off and unplug it from the power supply.
  • 2 Remove the lower dish racks and locate the filter compartment on the bottom of the dishwasher.
  • 3 Unscrew the filter housing and gently pull to lift out the filter.
  • 4 Use a few drops of dishwashing liquid, warm water and a soft-bristled brush to clean the filter and the filter housing.
  • 5 Dry the filter and the housing and reassemble them. Reposition them in the bottom of the dishwasher and turn until locked into place. Replace the racks and close the dishwasher door. Plug back in to the local power supply.
  • Jul 07, 2011 | Dishwashers
    Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
    Hello there:
    If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
    Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
    Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
    Maytag mdb3700awx dishwasher doesn't turn on
    check the house power supply to the dishwasher. If that isn't the problem, replace the switch control, part # 99001611
    Nov 12, 2009 | Maytag MDB7100AWB Dishwasher
    My maytag dishwasher lower and upper spray arms are working intermittently. Sometimes there is plenty of water spraying around, other times, I can hear what sounds like the motor running but the arms are...
    Pour 1 Cup of Muriatic Acid (Can be purchased at your local Pool Supply Store) into the bottom of the washer and a little in the soap dish. Run the Dishwasher through 5 cycles. Check to see If this helps. If not Try the same process with CLR house cleaner.
    Oct 22, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
    Power not coming on
    When a dishwasher appears to be dead, many times the door latch is to blame. On some models, that latch has a safety interlock switch directly controls the power, so that when the door is opened during a wash cycle, power is removed.
    The problem is that the interlock switch can fail or get un-aligned, so the dishwasher does not get power.
    Depending on your skill level, you can investigate the problem, using a phillips screw driver to open up the latch so you can see the interlock.
    Good Luck!
    Apr 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
    Water over flow on a1267302ew DWU9200ABX Maytag dishwasher
    There are three common causes for water leaking from a dishwasher door or float.
    1. A problem with the wash system. Check the wash arms for cracks and or splits in the underside that can cause water to jet down and out the front of the unit. Check all water supply tubing in the unit as this can cause the same problem.
    2. It is not uncommon for a water inlet valve to fail open and allow too much water into the tank causing a leak.
    3. Over sudsing can cause a leak. Make sure fresh dishwasher detergent is used in moderation.
    Go here for Maytag Dishwasher Parts: http://www.repairclinic.com/Maytag-Dishwasher-Parts
    www.RepairClinic.com
    Feb 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
    Brand new dishwasher installed and water leaks out bottom of door
    Main tub seal
    Door gasket or seal
    Water-inlet valve
    Hoses
    Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
    Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
    • Lower rack
    • Spray arm
    • Spray arm support
    • Wash/drain impellers
    Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
    Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
    The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
    Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
    Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
    Leaking dishwasher
    hi there,
    dishwasher leaking might be due to either of these causes, check these:
    Main tub seal
    Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
    The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
    leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
    remove the:
    * Lower rack
    *Spray arm
    * Spray arm support
    * Wash/drain impellers
    Then try the seal out of its housing and replace it.
    Door gasket or seal
    Water-inlet valve
    Hoses
    Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
    Maytag MDB7100AWB Dishwasher Logo
    304 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
