Question about Orion 1200D Car Audio Amplifier
Orion XTR PRO 2400 power on... no sound
Ive had this amp running 3 12s at 2.67 for a while without any problem ,one un hooked it and i think a speaker wire touched the remote , it powers on but has no sound ive been inside with a magnifying glass and couldnt find anything . can anyone help?
It could be that it burned the stereo inputs or outputs
Posted on Feb 26, 2008
I have an Orion 2150sx and an Orion xtr2150 will either of these run on a one ohm load ? If not what is the best way to run either of these amps to get the most power out of them. I have two Orion xtr...
EITHER OF THEM WILL WORK AT ONE OHM WITH NO PROBLEM, MAKE SURE YOU MAINTAIN VOLTAGE INTEGRITY, USING EITHER 2 OR 0 GUAGE POWER AND GROUND AND A POWER RATED ALTERNATOR AND BATTERY.
Nov 03, 2010 | Orion 2500D Car Audio Amplifier
My amp works when the volume is low, but if i go higher it turns off and then it power up again but i can't go higher, what will be the problem
Your Output devices are most likely going faulty. When that happens your protection mechanism is cutting in. OR it could be a speaker problem, You manual to troubleshoot is below. www.teamcsw.com/manuals/orixtrpro1000_2400.pdf
May 21, 2010 | Orion XTR Pro 2400 Car Audio Amplifier
Will not power up
Hard question to answer because of the lack of information, but my first guess would be the remote turn on wire and my second and third gueses would be a resistors or a blown fuse.
Oct 17, 2009 | Orion XTR Pro 2400 Car Audio Amplifier
Wiring diagram
Hello rivertoyz,
If your F250 has the stock radio, there are no preamp outputs, so you will need to use the speaker outputs. The best solution would be to wire a LOC (line output converter) to the rear channels and run RCA cables to the amp.
Speaker wire color code:
Left rear positive - Gray/Light Blue
Left rear negative - Tan/Yellow
Right rear positive - Orange/Red
Right rear negative - Brown/Pink
You'll need an amp wiring kit with 4gauge power and ground. Both the LOC and wiring kits are available at numerous online stores. The best service is from www.crutchfield.com. Another reputable online seller is www.sonicelectronix.com.
You did not say what subwoofer(s) you intend to use with the amp. If you want to stick with the Maxxsonics product, a pair of 10" Orion HP10D2's would be an excellent match. Wire each of the subs dual voice coils in series for 4ohms, then parallel them to the amp for a final load of 2ohms. Both of the linked retailers above sell the Orion's and many other brands as well. Just make sure that your sub selection has adequate power handling capability. At least 1000 watts RMS if you use a single sub and 500 watts RMS if you go with 2.
Hope this helps.
Jun 01, 2009 | Orion XTR Pro 2400 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w subs
the speakers most not go lower than 2ohms.when the amp. is bridge you are connectin 2 channels.your speakers are most important,the impendence of it,in ohms e.g 4ohms or 8ohms.note make shore the amp.can go down to 2ohms when bridge,or connect the speakers in series.if you not shore.
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Feb 25, 2008 | Orion XTR Pro 2400 Car Audio Amplifier
Orion XTR Pro 1000 amp ticking
the amplifier output transistor or ic may be damage, its the relay may be thats ticking, or if not the output going to the speaker may be shorted or overloaded with low impedance, you may remove some speaker and try again.
May 18, 2007 | Orion XTR Pro 1000 Car Audio Amplifier
Orion 1200D Car Audio Amplifier Logo
278 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
