Question about Kenmore 53642 / 53644 Side by Side Refrigerator
No cooling no freezing puddle on floor
Kenmore model 59562998 made in 1999 . There is no water in the pan underneath, it is bone dry. Looks like the water came from the very front of the freez side of the side by side
  • 5 more comments
  • monicam5 Apr 23, 2009
    would that keep it from cooling/freezing... I hear no motor noise at all but the lights are on??
    no ice build up..I hear no motor noise but the lights are on?? I actually replaced the fan last year and it was working this morning although I could tell nothing was cooling and evrything was melting
  • monicam5 Apr 27, 2009
    the model number is 10659562990 I replaced the defrost timer. Got it at a Sears parts place...it was an 8hour timer the one i took out was a 10 hour...anyway when plugged back in still nothing only lights no motor noise or compressor noise...been waiting on a repair person from Sears to show up for $65 ...just to trouble shoot...any help is greatfully appreciated...
    No the fan is not on...I did replace that last summer. When I replaced the defrost timer it had an extra black wire that I thought was a ground wire and I left it lose. because there was another ground wire already attached to the wire harness. maybe I should have attached the black wire some where? I think I had motor noise before I started messing with this... I am a try it yourselfer...everyone tells me they would have called a repair person...I still believe someone here can help me...
    the repair guy also told me the black wire does need to be connected and showed me on the directions what to do with it...but also like you suggested I put the old one back in..but I'm going to try the new one again hooked up right this time...I'm really missing my refrigerator...thanks for helping me
    Thanks everybody after a few long minutes it is running and working great...It was the relay switch that attaches to the compressor...the original defrost timer is back on. I couldn't believe it took it so long to start running?? More details in my other post in case someone else has the same problem...I really appreciate everybody answering my post..Have a great week
  • monicam5 Apr 28, 2009
    Hope I gave you what you needed...sorry for the delay..great site ..thanks for all the help!
  • Kenmore Master
  • 3,361 Answers
Your defrost drain line is frozen over. Turn off the fridge and defrost the drain in the lower rear portion of the freezer.
Posted on Apr 23, 2009
  • 7 more comments
  • steve
    steve Apr 23, 2009
    Is there a ice buildup on the back wall of the freezer?
  • steve
    steve Apr 23, 2009
    Is the fan at the compressor running?
  • steve
    steve Apr 23, 2009
    There are 3 numbers ahead of the model number you posted and a period. What are the 3 numbers?
  • steve
    steve Apr 27, 2009
    Is the compressor fan motor running on the rear?
  • steve
    steve Apr 27, 2009
    If the fan at the compressor is not running there is probably no power going to the compressor from the thermostat control or the defrost timer.
    Find the defrost timer and turn it a click or 2 and see if it comes on.
  • steve
    steve Apr 27, 2009
    I just re-read your notes. All the wires on the defrost timer must be connected.
  • steve
    steve Apr 27, 2009
    If you still have your old timer re-connect it and tell me what happens.
  • steve
    steve Apr 27, 2009
    I have been 4 days off and on trying to help you.
    Would you please rate the help?
    Thank you.
  • steve
    steve Apr 28, 2009
    I just wanted to make sure I gave you what you needed.
    Glad it is working for you.
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Mdz2766ge maytag fridge; water puddles on floor when defrost kicks in
Check the drain tube from the defrost coil near the evaporator to the drain pan.
Jan 29, 2014 | Maytag Refrigerators
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
I have a 5-year old Goodman furnace/AC. It has a drain trap on the side which looks like a cup with 2 hoses coming into it from and a drainage pipe coming out into the sump pump. Recently I noticed a...
Hello, it sounds like your condensate line is clogged and not be able to drain into the condensate pump or your condensate pan is cracked and leaking. Best thing to do is clean the condensate line with a shop vac and see if the water will start to drain, if not looks like the pan is cracked.
Jul 13, 2011 | Goodman GMS90703BXA Heater
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Water won't evaporate from defrost tray. Fills up and runs on floor
the problem is he defrost drain from freezer is blocked and needs cleaning out
dismantle evap cover to get at drain
Mar 07, 2008 | Kenmore 64522 Top Freezer Refrigerator
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
223 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
