I have 2 computers and 1 hp printer. i am trying to print with both computers to the one printer. we have an internet router and both of us are online using it. we have ethernet cables coming from it to our computer so that we have internet access. we just dont know how to network them to print on the one computer.
If you're using "XP" these are the steps to get you started, if it's Vista, it should be similar, but I'm not familiar enough to know exactly:
To setup network:
Open "control panel"
Select network setup wizard"
"welcome screen" opens, select "next"
Make sure other PC is on and Click "next" again
Select "this computer connects to the internet through a residential gateway....." click "next"
Type in "description" and "name' (it's up to you) click 'next"
Type a workgroup name or use default "MSHOME"...NOTE: this needs to be THE SAME on the other PC when you perform these settings there.
on the next screen, slect "turn on file and printer sharing", click "next", click "next. select "just finish the wizard..."
Restart the computer, then do this on the other PC
Printer sharing:
connect the printer to one of the PC's and install driver if it's not already, during the install you will be prompted whether to "share" or not slect "share and name it.
NOW.....to connect form the other PC.....go to "printer/faxes", "add printer", click 'next" select "a network printer...." click 'next"
select "browse for printer"
in the larger box it may just show the printer, or you may see "Microsoft windows network", if so click on it, then select your network (IE: MSHOME") and now you should see the printer. Double click it, and that should do it.
I hope this does it for you, if so, please, please rate my solution :)
Posted on Apr 23, 2009
My printer keeps going offline. What can I do to get it back online?
I understand your Printer is offline on your Windows 8 computer.
The easiest thing to do is just rebooted everything. Turn off router, computer and printer.
Wait a few minutes and turn on router, computer and printer.
Before trying to print make sure there is nothing waiting to be printed. Right click on your printer and see whats printing. Remove if anything there. Try to print again.
If the printer still showing offline try installing and running HP Print and Scan Doctor.
Download and install at this location.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&jumpid=ex_r4155/hho/ipg/ccdoc/p...
Let me know how this goes.
Thanks
Mar 23, 2016 | HP PSC 1410 All-In-One InkJet Printer
IP address for HP deskjet f380 all in one printer
HP Deskjet F380 Printer: Trying to connect printer to phone with an IP address:
Hello. The HP Deskjet F380 is not a wireless printer.
Others online have been successful connecting this particular printer to their Android device using an OTG cable:
..However, the HP Deskjet F380 is not compatible with the Android Printing feature as noted by HP Support here (for Android OS Kitkat and above):
HP Printers Mobile Printing in Android Kitkat Using the Android Print...
If you try to connect this HP Deskjet F380 to a Windows phone it is also not compatible.
Reference Links
HP Print Service Plugin Android Apps on Google Play
HP Printers Mobile Printing Solutions Compatible with HP Printers
F380 printing from android device
HP Deskjet F380 all in one printer
Jan 21, 2016 | Samsung Cell Phones
Hp laserjet m1522 printer unable to print after i change router
I would not post your ip address to either of these online. someone with a small amount of routing skill could cause some damage with that info. just saying. i have no answer to you question just trying to help you otherwise.
Feb 12, 2013 | HP LaserJet M1522 MFP Series PCL 6
HP Photosmart C4780 and Acer Aspire fight over web-based printing!
Try hard-wiring your laptop to the router with an ethernet cable as a test and then try printing, if you do not loose connection to the internet then the problem is probably that the printing is hogging your wireless bandwidth.
If the same thing happens with loosing connection to the internet try connecting to the internet real quick through another computer that is hardwired, you want to find out if the problem is a wireless one or that affects wired computers also. You might need a driver upgrade, you also might need to upgrade the firmware of the router
Jan 22, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
I have 3 laptops connected to a bell 2wire router. They are all able to connect wirelessly to the router and access the internet fine. But I am trying to connect my hp2605dn printer to the router with a...
To install a HP printer (with built-in Jetdirect print server) as a network printer you need to do the following -
1. Open the printer’s menu and enable the Network Card – then configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100 then set the Subnet Mask IP address to 255.255.255.0
If you have a wireless router then check the IP addresses that the router issues to the computers on your network and configure the IP address in the printer accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
Install the HP printer driver on every computer on your network and configure the printer’s TCP/IP port as previously detailed.
Do a test print page to check the printer.
You can now print from any computer on your network.
Dec 03, 2009 | 2wire Computers & Internet
HP C4580 won't go online
Thank you Nadine,
yes - the plot is thickening now!
To your problem:
The printer itself will never go online. If you want to print something from the internet (a web page i.e.), your computer is establishing that connection via a web browser (Internet Explorer, Firefox, etc.), like the page you see right now.
If you want to print something, you have to choose the "Print" command form the "File" menu in your application or hit the "Ctrl" key and "P" at the same time.
In the upcoming dialog you can choose your printer and the printing preferences. Try it right now and print this page. (Make sure you select "1 to 1" in the "Print Range" options, otherwise you might end up with a lot of scratch paper...)
Did it work?
If so - any other questions?
If not, post a comment and tell me what happened.
Jan 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
"The process mdns stopped unexpectedly..."
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are these printers connected with a LAN cable directly to the router, or are they wirelessly connecting to the router?
HP C8180 has built in wireless adapter and Ethernet according the Website at HP.
If this is connecting to the network wirelessly, check to see that it is connected to the Network, is your router using secure passwords for a connection to the network,
Your printer will need these passwords just as your computers would
If you connect the printer with a Lan Cable, it will be more reliable, and shouldn’t need a password to be on the network. And makes life a little easier...
Your internet provider has nothing to do with your Printer not printing; this is an Internal Network Problem. The settings or your network has changed.
The Printer should have a static IP address
Here is a link to a tip I put together about this subject,
http://www.fixya.com/support/r1173875-network_connected_printer_not_printing
If you need any further assistance, feel free to contact me...
Oct 26, 2008 | HP Photosmart C6180 All-In-One InkJet...
Epson aculaser c1100 will not print from any of 3 computers on network
The IP number on each computer was wrong in one number, despite having printed for 20 months previously.
Oct 06, 2008 | Epson ACULASER CX11NF All-In-One Printer
NETWORKING
yes of course you need a wireless router for that. wireless router are for wireless network (desktop pc also needs WAN)
Feb 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer won´t work
hp provides a line of wireless printers and sometime printer won't print with wireless...so here is what you may have to do in order to het this fixed
1. make sure your wireless password
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with hp Printer Tech Support
3.. now type the right password and try to print it
ihope this may help you
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
216 people viewed this question
jasbo
jasbo
