Question about Amana NDG233AW Gas Dryer
No heat, dryer exhaust vent cleaned, still no heat, gas line is on
Amana Dryer Model#ndg2330aww- the dryer runs fine but all of a sudden doesn't heat. I checked the exhaust hose and thats clear of debris.
  • 70 Answers
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
  • Randy Mothorp
    Randy Mothorp Mar 16, 2014
    I didn't mention it but is an electric dryer
I have an Amana gas dryer DLG330RAW that doesn't heat. When I turn on the dryer the ignitor glows red, and ignites a flame for about 5-10 seconds, then I hear a click and the flame shuts down. A few...
it sounds like there's a block somewhere in the system,unplug it,get a shop vac and a brush,vac up all the lint you can see then set the shop vac up to blow and blow all the lint off of the motor,out of the gas tube where the ignitor is and then clean out the duct that the lint filter slides into,pull the vent line off of the back of the dryer and start it and see if that makes a difference,also on the blower wheel housing there's a cycling thermostat part number 37001136 that could be bad or if you use cling free sheets the back of the t-stat could be covered with the white powder from the sheets and lint,you can try cleaning the back of it off but it sounds like you have a block somewhere,if the dryer does run good after you clean it out and run it with the vent line off the block most likely is in the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint out of it to the outside,make sure there isn't a cage or anything outside that's blocking the vent.i know you say it's clear but check it again before you start changing parts it sounds like bad air movement.good luck and if possible let me know what you find.
Sep 01, 2013 | Amana DLG330RAW Gas Dryer
Amana ALG443raw gas dryer
sounds like the thermostat is shot..do you fix this sort of thing yourself?
Mar 17, 2008 | Amana ALG443RAW Gas Dryer
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Dryers
My gas dryer doesn't heat very well, if at all. Do I need to replace parts or are there ways do check and clean parts.
First i would clean the dryer vent. If the vent is clogged then the dryer cannot circulated the air inside the dryer. This will cause long dry times. If the dryer heats at first then doesnt heat anymore after about 10 min you probably need new coils
Jul 15, 2011 | Amana ALG443RAW Gas Dryer
Dry will not blow heat
Check the entire exhaust vent tubing before buying anything for this dryer to repair.. Most dryers only need a good cleaning to get the heat back running correctly. A moister sensor is working if the lint build up is more than just dust in the vents tubes. Any build up the sensor detects and keeps the heat off. Sometrime you will get heat for awhile although it will shut the burner down quit soon
Jun 09, 2010 | Amana NDG2335AW Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
How to remove lower front panel/amana gas dryer model ndg2330aww
look under the fornt panel 2 5/16 screws holding it on
Jan 15, 2009 | Amana ALG331RAW Gas Dryer
Amana dryer model #LG4309W doesn't heat up like it used to
you need to get a vent cleaning the recommend that you get one evey 6 months with a gas dryer.
Dec 10, 2008 | Amana ALG443RAW Gas Dryer
Amana NDG233AW Gas Dryer Logo
532 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
