Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox printer xd100
I have an error code of h4 displayed is ther solution?
  • 1 more comment
  • Joe Beecroft
    Joe Beecroft Oct 02, 2007
    this is amazing that it worked, all other solutions have you taking the machine apart
    thanks
  • Anonymous Dec 02, 2007
    h4 error code
  • Anonymous Jan 07, 2009
    I had the same problem after our power went out. The manual that came with the copier was not helpful, however, your fix worked wonderfully the first time. You saved us a repair bill of unknown amount, but usually not cheap. Thanks so much, Cathy
  • 161 Answers
H4 is a power failure code. To reset the error please press in the following order: CLR - AUTO - CLR - AUTO (this puts the unit in tech mode). Enter 14 (as if asking for 14 copies) Press "PRINT" Your unit should reset itself and start working.
Posted on Oct 02, 2007
There is the complete procedure to reset this code:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=393,E=0000000000178244991,K=3206,Sxi=3,Case=obj(23198)
good look :)
Posted on Oct 22, 2007
Control panel shows "H4"
This is a solution from the Xerox Support website (www.support.xerox.com) Give it a try and hopefully it resolves your problem. Take care & good luck.
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 03, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
We have a workcenter pro 45. The new fuser module is on order, but the fuser model went out today. Is there a way to override the error until the new module arrives?
What error? H4? If so then you can get the reset procedure by searching my tip for this under "Sharp AL series H4"
Your Xerox XD100 is made by Sharp
Mar 19, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
H-4 error code is displayed.
What you want to do, it turn the maachine off and on, then press Cleat, Auto, Clear, Auto. That is the pinkish clear button and the auto exposure button. Press in order Clear, Auto, Clear, Auto, the display will go blank. Enter the number 14, enter that as if you were going to make 14 copies, press start, That will reset the machine and it should run fine.
Feb 03, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Workcentre Pro16fx - H4 error code after power outtage
You shut the machine off then on, Press Clear, auto,clear , auto, then when the lights go out, program it as if you were running 14 copies. press start and that should reset it.
Thats the redish pink clear button and the auto exposure button, Clear, Auto , clear auto, and the display goes blank , enter 14 and start. Dont ask me why I repeated that LOL
Feb 02, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
Jan 17, 2009 | Xerox WorkCentre M20i All-In-One Laser...
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
Press "PRINT"
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
416 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
