Question about Toshiba Satellite A60 Notebook
How to check bios update requirement
My notebook got heated up while working for an hour at least. after that it shuts down. i want to know where the problem lies, how to find out, and rectify. my fan is working fine.. but the battery led remains orange most of the time. i use my notebook on ac power.
    Problem Solver:
  • 17 Answers
The problem lies on the board. Either you have memory issues or a faulty motherboard. The battery when it goes bad it does not let you turn on the laptop.
Posted on Sep 24, 2007
Hi, I am laptop engineer I have Sony VGN-CR363 Laptop problem is abnormal shut down without warring laptop will shut down please send the salutation.
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
May 28, 2011 | Computers & Internet
How to reset bios password of hp 2530p notebook? a) Flashing BIOS anew won't work (password required) b) Removing RTC battery inside for one hour won't work either
o check the current BIOS version on the computer, follow the steps below:
  1. Click Start , and then click Shut Down .
  2. Select Restart , and then click OK .
  3. When the first screen appears, press F10 to enter the BIOS Setup.
  4. The BIOS revision is listed on the Main menu.From there look for administrartor password and disable it. Make note of the current BIOS version; you will need this information to determine if a newer revision is available.
  5. To exit the BIOS setup, press F10 , select Yes , and then press Enter .
Nov 28, 2010 | HP EliteBook 2530p Notebook
My laptop got heatup
Please update the BIOS of the notebook and check if it works,
Also remove the battery and use the notebook on Ac Adapter power and check if it resolves the issue.
If not then you need to repair the notebook from service center.
Jun 10, 2010 | Compaq Presario C700T Notebook
Random shutdown problem
This is one of the common issues with the hp notebooks , actually what happens the vents are on the bottom pannel , of the notebook so if you do not use the chill mat , the notebook will get overheated . so i will recommend you not to keep the notebook on bed, or on the lap , because the vents are on the bottom pannel , also check the rubber feet of the notebook , if the issue persists i will recommend you to update the bios from the following website :-
You can also try updating the display drivers from the same website.
If the issue still persists , contact hp tech support (if the notebook is in warranty), tell them that the notebook is getting over heated and you are not able to touch it , they will take the notebook in for service.
I believe this will resolve your issue.
Mar 19, 2010 | HP Presario C700T Notebook
Computer Screen Randomly Shuts Off
-try to update the BIOS, its also possible that your notebook is infected with malicious software. If you have a anti-virus system try to run a full scan. You can get the BIOS update from the website, go under support and drivers section. Select the see support and troublshooting information. Type in your product number. So you can get the updates specific for your notebook. Also check your operating system if it is a 32-bit or a 64-bit.
Feb 28, 2010 | HP Computers & Internet
Toshiba Laptop turns itself back on after being shut down
go to toshiba's website select your proper device and go to support put in your model number there have been some bios updates to resolve this issue. load all bios updates and you should eliminate this known issue.
good luck!
Jul 18, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
PC suddenly shuts down on its own.
in this case pc only shuttdown automatically when the sensor of processors detects or reach the maximum temperature of the system. try to check the CPU FAN if running poperly. RAM also causing sudden shuttdown.
Jul 02, 2009 | HP MINI 2133 Notebook
Slow graphics in gaming
Please make sure the video card driver is updated and also the Bios.
Make sure the ac adapter is connected to the system while you are doing the bios update.
Update these drivers
and let me know if it does not work.
Also please post the system requirements for your games so that I could check whether this laptop will be able to run these games.
Also would like to know do u have an integrated video card or a discrete video card. This is very important when you are trying to play games.
Thank you
Dell Expert
Jan 06, 2009 | Acer Aspire 5610-4648 Notebook
Toshiba Satellite A60 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
