Question about Toshiba DOCSIS Cable PCX2200 (DAZ8817F-R) Modem
PCX2200 cable modem does not get IP address
My cable modem seems to have quit working - no cable light and no IP address - is there a default address you can get in through the LAN side and do a software reset? unplugging does not do any good and I can't find a reset button on it.
    Scholar:
  • 87 Answers
First of all.. is it working at all right now? Does it route and let you onto the net?
You need to find the factory reset switch. Usually they are a tiny hole which you need a paper clip for. They are usually on the back. Insert the paper clip and touch the reset switch. You only need a light touch and you should feel a click.
Obviously the power has to be on while your doing this....
The IP address might be on a sticker on the bottom of the modem. The factory default address is likely to be 192.168.1.1 or 192.168.0.1 or something like that. Let me know how you get on...
Posted on May 27, 2009
Hi, Our modem seems to work fine when plugged directly into a computer (we get internet okay), but if we plug it into anything else it won't get internet. We've tried two different routers and a Wii and...
Without further information, my best guess is that your modem has the same IP address as the common IP address for routers and probably the Wii. Most wireless routers have the address 192.168.1.1
Try connecting a computer using a hard line (a network cable) to your router and type in this address, it will most likely come up. If it does change it's static address to 192.168.1.12 (actually any number behind the last period above 1 and under 255.). Also set its gateway to 192.168.1.1 to access your modem. (Also in the router settings which are found by typing the address mentioned above, 192.168.1.1) Be sure to note this new address if you want to access your router without resetting it and using a hard line again. The Wii should automatically pick up signal from the wireless router. If for some reason you want to switch between the Wii and a Router by way of hardline, you must contact the maker of your cable modem (or cable company) and find out what the IP address is in order to access it's settings (the same way; by typing it's IP address into a browsers address bar.) By setting the modem to have a different IP there would be no conflict with the other products which (rightly) have the IP address of 192.168.1.1 as a default.
Hope this helps!
Dec 08, 2010 | Zoom 5241 Modem
How do i setup the 3g wireless internet on the dir 412?
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
Also:
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Power cycle the cable modem and router:
  • Turn the cable modem off (first)
  • Turn the router off
  • Leave them off for 2 minutes**
  • Turn the cable modem on (first)
  • Wait until you get a solid cable light on the cable modem
  • Turn the router on
  • Wait 30 seconds
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-412 Mobile Broadband Wireless...
What is the IP address for WF719CAPR? I am having problems enabling the modem. Please help
to get the IP Address for WF719CAPR
1. Connect that device ( a modem? or a router?) to your computer via ethernet cable (Turn on your router or modem)
2. Click "Start"
3. Click "run"
4. Type "cmd" without quotes on the window
5. On the black screen type "ipconfig" without quotes and press enter
6. Check for the "Default Gateway" whatever's in there that's the default IP Address of your (router/modem) or maybe a different IP Address if the ( modem or router ) is not reset to default.
Dec 30, 2009 | GigaFast Ethernet WF719-CAPR Wireless-G...
Will not connect to internet completed all connection but cannot connect to internet
Router's have their usual way for them to work with your preferred Cable / DSL Internet Service Provider.
Cable Internet usually requires a MAC clone and power cycle to work properly while DSL Internet often required a username and password that came with your DSL povider.
If you want to configure your D-Link router then try accessing it Web Interface;
This instruction is for Cable modem installation however if you're using DSL modem then just change the WAN connection type to PPPoE and type your user name and password.
  • Wait 30 seconds
Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address.
Hope this helps!
Oct 15, 2009 | D-Link Computers & Internet
I want to change usb to ethernet interface. When I try to do it is failing to communicate with the modem
Whenever you swap the Ethernet and USB connections, it will fail to work as the modem is still configured with your computers IP address on the port you are changing FROM. Since the computer has not used the Ethernet port after being changed from the USB port, the modem has no IP assigned.
The solution is simple and must be done ANY time ports are changed, either ones on the modem, or if you were to change Ethernet ports on you computer.
Swap your connections, then reset the modem by unplugging it's power cord on the back for at least 10 seconds, then plug in.
This forces the modem to reconfigure it's ports, and to re-issue the IP address to your computer on the new port.
Since the modem only configures a port when the computer is plugged into it as it starts up, the other one is left in an unusable state.
The same equally applies if you were to add a second computer using the second modem port. You would also need to reboot the modem. Note that using both ports on the modem, each of which gets a separate IP from the ISP, is usually disabled by your cable company as you normally have to pay extra for multiple IP addresses. Sometimes the ISP overlooks this and you can get away with a free second IP address as I did with this same modem... until they wised up! Now I can use either port, but not both together. Only one get's an IP address.
May 05, 2009 | Toshiba PCX2200 (pcx2200key) Modem
Change modem default ip address - conflicts with other routers
The motorola cable modem ip address cannot be changed
May 01, 2009 | Computers & Internet
Zonet zsr1134we router abruptly stopped working
make sure your modem and your router are not using the same ip address. Many items default to 192.168.1.1. A reset of either device could return it to use this ip address.
No Internet is exactly what you get if your modem is 192.168.1.1 and your router is 192.168.1.1. The problem can happen if either device give out an ip address already used on the network. Change which ever one you can most easily find the documentation on.
I don't recommend using static ip addresses internally, unless your documentation requires it for your setup. changing the set of ip addresses that are distributed by DHCP is the best was around this problem.
Mar 23, 2009 | Zonet ZSR1114WE 802.11g 54Mbps Wireless...
Signal found, but no connectivity
Try this. It should renew your configuration between your router and your internet provider:
Note: The 192.168.0.1 address is NOT on the internet. It is the address to the router itself.
Step 3 Click on Status. Under WAN, Click DHCP Renew. If it does not get an IP address or times out, then continue with Step 4.
Step 4 Power cycle the cable modem and router:
Turn the router off
Turn the router on
Wait 30 seconds
** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Step 5 Follow Step 1 again and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not already have a public IP address under the WAN heading, click on the DHCP Renew and Continue buttons.
If you're still getting no connection to the internet, another alternative (before chucking the router) would be to reset it to factory defaults, and run through the setup process again, from scratch.
Cheers
Nov 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Router as cable modem
This answer is for a Dynamic and Static Cable connection (I.E. ATnT-BI, Cox, Adelphia, Rogers, Roadrunner, Charter, and Comcast). Note: Please configure the router with the computer that was last connected directly to the cable modem. Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click on the Basic Setup tab. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Save and Restart. Step 3: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4: Follow Step 1 again and log back into the web configuration. Click the Device Status tab . If you do not already have a public IP address under the WAN Ethernet heading, click on the DHCP Release and Renew buttons. Setup Static Cable Connection Step 1: Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2: Click the Basic Setup tab. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. Note: If you do not know your settings, you must contact your ISP. Step 3: Click on Save and Restart. Step 4: Click on the Device Status tab and verify that you have a solid link between the router and the modem. If you do not have a solid link between the modem and the router follow the steps below: # Power cycle the cable modem and router. # Turn the cable modem off (first) # Turn the router off # Leave them off for 2 minutes** # Turn the cable modem on (first) # Wait until you get a solid cable light on the cable modem # Turn the router on # Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Cable modem connection
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router. Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes. Step 3 Power cycle the cable modem and router: Turn the cable modem off (first) Turn the router off Leave them off for 2 minutes** Turn the cable modem on (first) Wait until you get a solid cable light on the cable modem Turn the router on Wait 30 seconds ** If you have a Motorola (Surf Board) modem, leave off for at least 5 minutes. Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address. Static Cable Connection The instructions below are for users who were given a static IP address from their ISP (Cox Business, TDS DSL, PacBell Business, Interbaun, InReach, Inficad, FlashCom, DCAnet, and Cavalier). Step 1 Log into the web based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing). Step 2 Click the Home tab and click the WAN button. Select the Static IP Address radio button and enter in your static settings obtained from the ISP in the fields provided. If you do not know your settings, you must contact your ISP. Step 3 Click on Apply and then click Continue to save the changes. Step 4 Click the Status tab and click the Device Info button. Your IP Address information will be displayed under the WAN heading.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Toshiba DOCSIS Cable PCX2200 (DAZ8817F-R) Modem Logo
388 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
