Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite top load about 3 years old
The machine works properly but after the water is spun out of the machine it continues to leak from the bottom of the machine and keeps the floor wet. I clean up the water and within a few minutes there is water all over the floor again
  • 447 Answers
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Posted on Sep 27, 2007
SOURCE:
Water pours in on spin cycle
The first thing i would check is your boot around the door for a rip or tear. Also check the drain line for any types of leaks. You can also remove the bottom panel there will be three torx screws and you can look at your drain pump while in spin and drain cycle to see of the leak located in that area.
Hope this helps _MJ_
Jan 29, 2010 | Kenmore Elite 45986 Front Load Washer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Top Load 5 years old which leaks ONLY during the spin cycles. I beleive it may be water coming over the top of the tub. I need to comfirm and get instructions on the removing of the...
it is the water pump probably it only pumps out and has pressure on it when it is spinning easy to remove just pull it away from the wall a couple of feet and tilt it back lay down on the floor and it is the first thing you see next to the front panel two clips and a couple of hose clamps
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite top load washer leaking
in the two front corners insert a putty knife and pry upward.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite 110.2949 water leak from center front of unit
Check your pump. The pump is located on the end of the motor. You can tip the machine back and pull the pump off to check it. After you take the pump off. Check to see if there is a water stain where the shaft of the motor goes through the pump. If so you pump is leaking.
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
101 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Paula Hamilton
