Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
My fridge runs but does not get cold or freeze
  • pretejam May 16, 2009
    My frigidaire refrigerator is not keeping things cold. A few weeks ago I broke the nob that turns the light on and off, and it has been on continuously since. Would the light being on constantly cause the temperature of the refrigerator to be off?
    Sniper:
  • 52 Answers
Your refrigerator is low on FREON.You will have to call a reptable appliance service person and ask if they give free estimates. Depending on the age of your refrigerator, it may be more cost effective to purchase a new one. If this has been helpful please rate my solution.
Posted on Apr 23, 2009
Kenmore 596 - temp control panel not responding when up or down buttons selected. Fridge too cold. Freezing items in fridge after power outage last night.
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Okay, hope this will help in solving problem
Aug 07, 2011 | Kenmore 26.0 cu. ft. Side-By-Side...
Fridge too cold. Cleaned the condensor coils, but its still too cold.
I hope this will help to solve the problem....
Aug 07, 2011 | Refrigerators
The refrigerator and the freezer are staying too cold. The temp controls are at the lowest possible and still things in fridge freeze. I can hear the compressor cycle of for a while then on for a while....
things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help out.....
Jun 09, 2011 | Refrigerators
My gsh25jsxjss fridge is too cold. the electronic settings do not change the temp in the fridge.... even if I put it on the warmest setting... food is freezing in the fridge area
HELLO,
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, please do check that to confirm the deflector is okay or not....
Hope this will help in solving the problem......
Jan 12, 2011 | General Electric GSH25JSXSS Stainless...
Lg fridge freezing food in freezer section
the cold control and the air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Hope this helping solving the problem.....
Aug 15, 2010 | LG LRSC26922S Side by Side Refrigerator
My fridge is freezing food in the fridge section. The eggs closest to the freezer are all frozen, vegetables are frozen.
the cold control and air deflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this help in solving the problem....................
Everything in my refrigerator is freezing and my ice machine wont work
Hope this helpout.....
Aug 11, 2010 | Kenmore 57029 Side by Side Refrigerator
Fridge is freezing
My fridge is freezing things: Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
A tip from Gerard in Georgia: My Sears ( Frigidare built ) refrigerator suddenly started freezing thing in the refrigerator compartment. I started to replace the cold control, not having found any other problem, when I discovered that the plastic air deflector at the top rear of the frig had been knocked off. I replaced it and all is OK. I thought you might add this to your suggestion list. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly. Luckily, I found this before rushing out to purchase the control.
Take care.
Jun 25, 2010 | Refrigerators
At first the freezer wasn't freezing and the fridge part was getting cold, now it's reversed, the fridge is not getting cold and the freezer does...It does runs, could it be freon?
Turn the freezing unit down to the lower number,and the fridge compartment up to about 7 or 8.Leave it over night to balance.
Mar 14, 2010 | Refrigerators
GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
Jul 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
690 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
