Question about AEG Lavamat 88840 Front Load Washer
How to remove drain pump on AEG 88840 washer?
Our 4 year old 88840 drain pump stopped working yesterday. I checked the lint trap and nothing in there. The pump hums slightly but doesn't pump and move any water. Everything else works and am not getting any error codes apart from a C2 when the drum had water still in it.
Assuming I can even get a new drain pump, does anyone know the easiest way to get access to it? I can see it at the front bottom of the machine but there is a steel plate below it and there is metal housing in front of it and to the side (plus the tub is in the way)?
Appreciate any advice or gem tips in advance... Robert - Calgary, AB
Hi
Not really a fix this but may get you going for a while.
We have a AEG 12710 update with what sounds like the same problem,If you remove the filter you can see the pump impellor and with the power off you can spin this a bit with a screwdriver etc and then box it back up and it should spring back to life for a few weeks.This is what we are having to do every few weeks until i get a new pump sorted.
Hope this helps
Posted on Dec 06, 2010
It doesn't get water or turn, it just hums
Hi, I posted my question yesterday with no help. Took matters into my own hands and I ended up having one of my 5 yr olds sock stuck in the pump. It was messing up my whole washer. It wouldn't drain or spin... Nothing!!!! All is good now, I'm washing clothes as we speak :) best of luck. It was an easy fix with no out of pocket costs.
Mar 04, 2013 | Washing Machines
Good morning. I have a GE Adora washer. Last night my wife let me know that it has not drained properly in the last two days. I removed and cleaned the lint trap. I then started the washer back up in the...
I see you have already attacked the filter! Were you able to test the motor in motion as well as checking if it was free? If not here are the last 2 paragraphs of my 'check drain filter and drain pump motor' guidance notes ;-0)
(REMOVE POWER)
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Mar 25, 2011 | GE WCVH6260FWW
Kenmore elite oasis gas dryer
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Won't drain or spin. Makes a humming noise?
Pump Blocked
Drain the machine off by putting the drain hose into a bowl and then remove the lint trap and clean out the pump
Feb 15, 2010 | Maytag Washing Machines
Clothes come out covered in lint and hairs.
Oct 11, 2009 | Kenmore Washing Machines
AEG Lavamat 88840 display C3
This means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!
Jan 02, 2009 | AEG Lavamat 88840 Front Load Washer
Machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Jun 01, 2008 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
624 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
