Question about Maytag MSD2758G Side by Side Refrigerator
CHANGED FILTER, HUGE INCREASE IN WATER DISPENSER PRESSURE
HAVE MAYTAG SIDE BY SIDE. AFTER 1ST TIME CHANGING WATER FILTER, THE PRESSURE INCREASED SO SO MUCH AT THE WATER DISPENSER IT'S ALMOST LIKE A GARDEN HOSE. IT'S CRAZY GOOD, BUT I'M WORRIED. ANYONE ELSE HAVE THIS PROBLEM? ANYONE HAVE ANSWERS? WAS THE ORIG. FILTER SO BAD THAT IT AFFECTED THE WATER PRESSURE IN A BAD WAY? I'M JUST WORRIED IT'S GONNA LIKE EXPLODE FRIDGE OR SOMETHING.
  • Maytag Master
  • 4,655 Answers
No it will be fine. Just think about all that small particulate stuff the filter caught and filtered out of your drinking water. The pressure will drop as this filter begins to collect particles from your water and be back to about the same in a few months. Sea Breeze
Posted on Jun 23, 2009
Ice maker makes small cubes. Low water pressure at door
Is water pressure to house normal? Have you moved Refrigerator recently? if so you may have crimped water supply pipe or tube.
Is the valve for that pipe full on? Or was it turned off to do something to the water supply? Last time Water filter was changed? Electric valve for water dispenser may be clogged. That's the last place I would look. Small cubes may be an adjustment or switch to cause partial fill.
Mar 17, 2015 | Maytag MSD2758GEB Side by Side...
Low water pressure in ice maker and water dispenser I changed the filter but water just dribbles out of water dispenser and ice maker makes hollow cubes
Make sure the water line to the back of the fridgeis not kinked.Ifit is replace it. Hope this helps,If so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Maytag MSD2758G Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
When water dispenser is pushed the water supply line rattles and very little water comes out. The water supply line has good pressure and the ice maker works. I also changed the filter.
Our water dispenser will work for about half a glass then the pressure immediately stops and the water flow goes to a small stream. Maytag MDZ2667HES Wide by Side. HELP! Filter was changed approx 3 months ago.
Oct 12, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Model MSD2651HEW - Changed Filter and
try checking your water resevioir it sits behind the drawers and sometimes gets ice crystals in it
take a hirdryer to the water lines that are exposed for a few minuts this might help
Oct 12, 2009 | Maytag MSD2651 HE Side by Side...
Low water flow after changing the water filter in a gf profile re
Just a suggestion, you could try installing a filter on the water supply line to the fridge. A nice one should dramatically lessen the frequency of replacing the one in the fridge. As for your the pressure being low, look for a kink or pinch in the water supply line.
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
How do I get the filter light off after changing the water filter?
PRESS THE LOCK AND LIGHT BUTTONS AT THE SAME TIME UNTIL LIGHTS BLINK.THEN IT WILL RESET FOR 12 MONTHS OR 44O GAL.HOPE THIS HELPS
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have the opposite problem
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
May 21, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How do you changing the water fileter
  • in case you haven't figured it out by now. open rt side door and top right corner is the filter push the little plastic tab and the housing drops down , a quarter turn counter clockwise and the filter should pull out, reinsert the new filter screwing clockwise and close housing, remember to pull water from dispenser right away you will have let air into system so some sputtering will occur till its purged
Feb 18, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Water line clogged
No to air, due to the small bore of the pipework they usualy run slow this assists the water to cool as it lows through the unit. Regards Advisor
Aug 23, 2007 | Maytag MFI2568AE Side by Side French Door...
Maytag MSD2758G Side by Side Refrigerator Logo
263 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
