Question about RCA P60828 TV
RCA big screen tv
I change the fuse in the tv but everytime I plug it back up the fuse blows out again. Is it something wring with the fuse box?
  • Anonymous Dec 29, 2007
    I HAVE A PROBLEM WITH THE TV TURNING ON AND OFF BY ITSELF. I CAN UNPLUG IT AN PLUG IT BACK IN AND THE TV WITHIN A FEW MINUTES WILL SHUT OFF AND A FEW SECONDS TURN BACK ON AND THEN OFF AGAIN....
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Posted on Oct 01, 2007
42 inch big sceen tv. sceen wilnot come on
Posted on Dec 21, 2007
SOURCE:
Rca TV MODEL #F31633SB NO PWR AFER BLOWING AC LINE FUSE
Some RCA models had problems with there degauss circuits drawing to much current at turn on. You can change the fuse to see if it will work for a while. If it immediately blows the fuse at turn on or at plug in, there is a hard short somewhere. If it works for a while and blows the fuse again, take it to a repair shop and have them modify the degauss circuit. An up to date shop will know what to do. Should not be expensive.
Oct 15, 2009 | RCA 20F511T TV
RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
Jul 21, 2009 | RCA L46WD250 46 in. LCD HDTV
Tv is pluged in,will not come on when on button is pushed
is the unit competly dead? no flashing lights.first unplug the set for 30 min then plug back up and try again if there is no lights then i suspect main fuse has blown. however this does not mean replaceing will fix. something has shorted to cause fuse to blow if there is flashing then the computer in the set has seen something wrong and shut down.
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA big screen tv
you got high voltage going somewhere that can be cuased by a blown fuse these rca big screen tv's have up 6 fuses one of them may be blow that needs replacing
Jul 03, 2008 | Televison & Video
No power no sound
oh noh!!! I suggest you should an AVR (automatic voltage regulator), these will help to control the flactuations of power. try also check the power supply (its either 110 or 220 volts), just make sure it is compatible to your default power supply.
Feb 05, 2008 | RCA HD52W58 52" TV
52 inch RCA big screen
check all connections and different sources(dvd, vcr, antenna) to make sure that it is the tv. otherwise i would say call a technician because you could be in for some extensive troubleshooting
Jan 25, 2008 | RCA P52960 52" Rear Projection Television
Blank
sounds like something in the regulator circuits blowing the fuse. I can post alink where you can get a service manual as well as free support to help you figure it out. Your set is coverd in the DPTV305 series phillips magnavox on page 2 of the phillips section for 10.99 and they email them instantly if you want one.
http://servicemanuals.vstore.ca/
Dec 08, 2007 | Philips 51PW9363 51" Rear Projection...
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
RCA 32V430T 32" won't turn on!
The fuse is inside the set and is probably ok, but check to be sure. If you have an ohm meter I would check the horizontal output transistor first. It is a big transistor on a heat sink next to the FBT. It has three pins, check the center pin to one of the others, if low the transistor and probably the FBT is bad.
Sep 05, 2007 | RCA 32V430T 32" TV
RCA P60828 TV Logo
188 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
