Question about Maytag Neptune MAH5500B Front Load Washer
Neptune Machine is filling really slowly and then the NF display comes on. There is no water pressure problem elsewhere in the house.
  • Maytag Master
  • 3,361 Answers
Remove the water hoses from the washer and clean out the filter screens in the water valve.
Posted on Apr 23, 2009
  • steve
    steve Apr 23, 2009
    Did you clean out the screens or just decide it must be something else?
What does nf mean
NF stands for no fill, which means you are not getting any water into the machine. This is either because the water valve has failed or is clogged, the water is turned off or the pressure switch thinks there is already water in the machine but the last is very unlikely.
Jun 22, 2012 | Maytag Neptune MAH6500A Front Load Washer
I'v washed 3 loads my Neptune washer and twice an message displays nf. What does this mean
It means no fill
Here are some things you can check
1.Is the water turned on?
2.Check inlet hose screens for restriction.
3.Check wire connections in harness leading from machine control board to pressure switch.
4.Check water valve.
5.Check inputs and outputs at machine control board.
Sep 24, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune gets a code of nf.
NF: no washer fill
Washer does not turn on water valves to fill washer with water.
Diagnosis:
May 05, 2010 | Washing Machines
Ine ia a neptune front load, nf comes up on the screen and it won,t do anything.
Hi dear I hope I have solved your problem
  • NF means No Fill
  • Washer does not turn on water valves to fill washer with water.
  • Is the water turned on? Check inlet hose screens for restriction.
    Check water valve.
http://www.applianceaid.com/neptune8.html
This site has everything you need to fix your machine
Cheers from the Gold Coast Australia
Jan 22, 2010 | Washing Machines
My neptune TL stops at 11 minutes and flashes "nf"
mattscott;
My comments are based on the FAV6800A/FAV9800A.
NF = No Fill. Your machine has reached a Control Board internal timer and has not seen proper signaling from the Pressure Switch for expected water fill for the wash cycle selected.
Possible fail points.
1. Pressure Switch is not signaling for properly tor water fill.
2. Water inlet valve is restricted or not functioning.
Please confirm your machine model number is it a FAV6800A or FAV9800A? I’m going to assume your machine model is a one of those models. Here is a link for the FAV6800A/FAV9800A Service Manual.
If you can let me know how much water is in the wash basket when your Control Board triggers the no fill error “NF” to the display? I would prefer you select Quick Wash cycle with minimal machine settings for the water fill. Do you have the issue with a cold temp select fill, a warm/hot temp select fill?
If you want to DIY I would suggest you become familiar with how to get in Service Mode. We may need to go to page 16 of the SM and possible check for correct Pressure Switch transitions in Board Functional Test Input Control Keys.
We will continue after your feedback…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code nf on display
nf code is no fill ,, washer does not turn on water valves to fill washer with water ,, , chk taps is the water turned on ? check inlet screens on hoses , check wiring connections in harness leading from machine control board to pressure switch,, check water valve ... check inputs and outputs at machine control board ,,
Dec 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Nf pops up on the screen & the washer stops
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
