Question about Toshiba TDP-T45U DLP Projector
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
  • 4 Answers
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Posted on Jun 24, 2009
Toshiba TDP-T45 projector, groups of vertical lines across entire screen. Someone said try setup frequency to someone else with same problem but that person said it didn't work, then someone said replace...
the tube referred to is the light tunnel. which in your case is not the problem. unfortunately the only thing you can do is give it a good slap on the top 3 inches behind the lens for an unlikely long term fix, or try reseating the main board to the light engine. if neither work then the main board or the light engine is bad.
Aug 07, 2010 | Toshiba TDP-T45U DLP Projector
I plugged in my toshiba DLP projector one day and I heard a pop
Sounds like a blown capacitor...they age...leak..and bulge..
and then blow out...
Check (visually) all the capacitors on your power supply board...
if they are fat, bulging or leaking...they should be replaced.
Jul 11, 2010 | Toshiba TDP-S8 Multimedia Projector
My TDP-S35 suddenly went to showing only in black and white. Any ideas? It was working perfectly and in the middle of a class it lost all color.
if this is a DLP projector, take the cover off and check the colorwheel. It sound to me like you have lost the segments off the colorwheel.
May 17, 2010 | Toshiba TDP-S35 DLP Projector
I am looking for a hardware that will allow me to install Toshiba TDP-T45 on ceiling.
you can get a universal ceiling mount from pc world or online at toshiba get any toshiba.
Feb 05, 2010 | Toshiba TDP-T45U DLP Projector
I have a toshiba tdp-t45 and a Dell D600 how do I get the image from the computer to display from the projector?
Connect the toshiba tdp-t45 to the back of the D600 and then hold down FN and tap F8. This will transfer the video to the tdp-t45. If this does not work for the first time try the Fn and F8 keys 2 - 3 times.
Rate if useful.
Aug 11, 2009 | Dell X2033 - Latitude D600 D500 Inspiron...
Toshiba TDP SC25 projector
The manual says it might be because the power went out when it was on. Just a note here, as projectors age they become more sensitive to power outages. When not in use turn off completely if you can. They have an on/off button.
Otherwise not sure but think you may need to replace the fan. Try cleaning it first but gently.
Jan 31, 2009 | Toshiba TDP-SC25U Multimedia Projector
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Nov 25, 2008 | Toshiba TDP-T45U DLP Projector
Toshiba TDP-T45U DLP Projector Logo
1,022 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
