Question about Refrigerators
Ice maker My G.E. Eterna refridgerator will dispense water or ice but will not create new ice . I had a tech out who I paid to tell me I needed a new mother board and it would cost about $500 . I paid $1300 for the fridge . So I bought a motherboard myself ($125), installed it properly . The fridge seems to work better but still no new ice . I really can't afford anything( no work since Sept.) so I 'm hoping to fix it for minimal. Should I have changed the thermostat ?( it is cheap in cost ) Or what else might work ?
  • Refrigerators Master
  • 4,655 Answers
Try filling the ice maker with water. If it works this one time check or replace the water control valve on back of refrigerator. Let me know, Sea Breeze
Posted on Apr 23, 2009
GE Eterna Series Side by Side refrigerator ice maker stopped making ice
Please try posting this question in the Kitchen Appliances/ Refridgerator and Freezer Accessories section. It is now posted in the Getzen/Eternana musical instruments section. Getzen Eternas are trumpets.
Feb 20, 2014 | Getzen 900S Eterna Classic Series Bb...
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
GE Eterna side by side fridge Model ESS2SLGMAWW
I've got the same problem...have de-thawed everything, (this was how we fixed it before) and still can't get water to dispense. Guess another 75 bucks service call...urgggg...
Dec 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
Eterna series side by side ice maker doesn't make ice
Hi: . In the warm weather your freezer can warm. I don't mean just frozen. Your freezer has to be at 0 degrees to harvest ice. Ice cream should be rock hard. Set your freezer colder and don't trust cheap thermometers. Also don't do the human thing and check the freezer every 30 minutes to see if ice is made. It will take 24hrs at zero degrees and opening the freezer a lot will not help matters. Hope this helps, Jeff This happens to me every summer. The ice maker will stop or slow.
Jul 05, 2009 | Refrigerators
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
