Question about Goodman Heating & Cooling
Need to Know Where to Change the Furnace Filter
I have a Goodman AC/Heating Unit. The heating unit model # is CHPFO-602A, serial # 0405162057. Where do u change the furnace filter at?
Thank u!
    President:
  • 710 Answers
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Posted on Apr 25, 2009
Trouble locating the air filter in the Goodman heating unit. CAPF036A2A
it will behind return air grille either in the room, ceiling, & i have seen them in attic in return plenum.
Feb 10, 2015 | Goodman Heating & Cooling
Blower fan not working
check for proper voltage from the transformer to the blower to see if blower is recieving voltage. check continuity on motor windings.....open loop indicates windings are shot
Jun 11, 2013 | Goodman GMS90703BXA Heater
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
How can I make the ac quieter inside the house?
If you have hard ducts, you can use some flex duct between the supply plenum and the hard ducts as a way to quiet the noise down.
May 10, 2017 | Goodman Heating & Cooling
I have a goodman heater and ac unit ,two stage ,problem the heat not very hot,feels more like luke warm.is there any way to addjust this.
Usually this is due to restricted air flow. So check the filter and ac coil (above the furnace) for filth and debris. Secondly adjusting the blower off delay dip switch on the circuit board could help some. Probably want to change it to a lower setting. Good Luck! :)
Dec 07, 2010 | Goodman GMS90703BXA Heater
Outside unit not running, inside unit is running, but blowin heat. Goodman unit MODEL CK-J60-1
eletrick furnace? then it is a stuck heat sequencer(relay) the first stage heat sequencer also runs the fan in heating
Jun 26, 2010 | Goodman CKL60AR60 Air Conditioner
How to change the filter ?
Your filter is in one of two places.
Either its in a filter grille or its at the furnace/air handler itself. If its in the grille, simply remove and replace.
If its in the unit, it will be at one far end of the unit opposite where the electrical connections are. It's uncommon for Goodman to be filtered at the unit as they do not have an independent filter access panel but I have seen it.
If its not in either of these locations, you either do not have a filter installed or your installing contractor has installed a filter box somewhere that will need to be located.
Hope this helps.
Jan 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Heater keeps going off on its on also fan not
Please provide more info. When it goes off does it come back on by itself or do you have to flip a breaker? Is the furnace gas or electric? If it is not moving enough air across your heat exchanger in a gas furnace or across electric heating elements this will trip a safety switch that will stop heating but not fan. Low air speed is most likely from inexperienced or improper duct design/ installation. Duct sizing is very important to move enough air. Don't believe me try breathing thru a straw. If your unit is a gas furnace it has a flashing code that will tell you what is wrong codes listed inside unit door. Could be lots of things. Reply with more info.
Dec 04, 2009 | Goodman Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
148 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
