Question about Toro Lawn Mower With Toro Power Tools
Lawnmower wont start after winter
I cant seem to get any type of a spark going.  The spark plug is clean.  When I push the primer, it feels like there is no fuel in it.  I think it used to make a liquid sound when depressed.  Now, there is no noise to the primer.  Fuel line seems to be clear, there was some water, and gunky residue in the reservoir.  Im not really mechanical.  These are just my observations.  I don't want to pay someone $100 for an obvious fix.
thanks.
  • sbkoncurat Apr 23, 2009
    Yes, I did leave gas in over winter.  Will gas additive clear up clogs in carb?
  • Dennis Yachimec May 11, 2010
    Did you leave gas in it over the winter and if so did you add the gas additive to it?
  • 473 Answers
SOURCE: starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Posted on Apr 06, 2009
  • 59 Answers
SOURCE: easy start self propelled toro lawn mower won't
it is hard to tell you that but if you take the the bulb plat of and blow it out it should work but make sure that the gasket is in place it well have a small hole ate the top i think fore the air to go threw it
Posted on Jun 23, 2009
rey12312
  • 36 Answers
SOURCE: fuel problem Starts fine but starts to die
ENGINES NEEDED TO REPAIR BY AUTOMOTIVE ENGINEER.
Posted on Aug 08, 2009
#1 Taper
  • 1040 Answers
SOURCE: we have a used Toro 521 snow blower without a
The rubber gaskets may have dried out because there was no fuel in it. The next time you store it, use : http://www.goldeagle.com/brands/stabil/default.aspx
For some reason I wasn't able to give you a direct link to this site, so you will need to copy and paste into the search bar .
But before you purchase new carb. parts, try this:
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris. (Should be able to see daylightthrough it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Nov 30, 2009
SOURCE: toro model number 200065 won't start. New gas,
some toro primer bulbs don't fill up with fuel but blow air into a chamber in the carb that has fuel in it so when you press the bulb, the air sprays fuel into the carb ( just a little) So since it won't start, the bulb probably has a very small crack in it. replace it and then try it.
Posted on Jan 18, 2011
Lawnmower won't start.
blades blocked?
Apr 25, 2017 | Garden
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
Lawnmower won't start. There is no primer bulb,supposed to start on first pull
Do you have fresh gas? Make sure the choke on carb is working, maybe drain the gas out of carb and or clean it out, check for spark
Aug 19, 2012 | Snapper 20 HP Lawn Tractor 2690578
Husqvrna hu775h wont start
Suggest start w/ the basics : Air, Fuel, & Spark. Internet search indicates that it's a Briggs & Stratton engine, which I just worked on yesterday (165 cc version). Easiest things first - ensure that there is FRESH fuel in the tank. If it's been sitting there all year, drain it out and refill with new fuel. (make sure you follow mfgr's recommended fuel type.) If you have a primer pump, make sure you can hear fuel flowing when you depress it (typically 3 - 6 pushes to prime the engine). If not, then youi may have a fuel line or fuel filter clogged. If you remove cowling/covering over top of engin, you can get access to the air cleaner. Remove the air cleaner/filter, and you can see into the carbuerator. This should make it easy to see if the primer pump is squirting fuel when depressed. While the air filter is out, make sure it is clean. If gunked up, I usually soak it and wring it out in fresh fuel, then let it air dry to clean it out (mine is made of foam). If it's a cartridge type air filter, blow it out w/ compressed air, or put a new one in if it's dirty. Lastly, if you have an assistant, you can check to see if you're getting a spark. Remove the spark plug, inspect if for correct gap and overall condition - remedy if you see something wrong. Then with it out, connect the spark plug cable (the high voltage line) to the top of the plug. Now, while touching the threaded part of the spark plug to a bare metal part of the engine case or lawnmower chassis, have your helper pull the starter cord and look at the plug's gap for a series of sparks.
If you don't see any sparks jumping the spark plug gap, you may have a bad plug, bad cable, too big a gap, or a bad magneto, or corroded connection to the top of the plug.
If you don't have fuel flow, you may have a clogged fuel line or fuel filter.
Air flow is pretty basic, so with the air cleaner removed, it should be pretty obvious if you have an airflow restriction. You can leave off the air cleaner/filter to troubleshoot the engine and to start it, just don't operate the mower without it, or you risk sucking in junk, rocks, you name it, into your engine.
THis may go without saying, but also inspect all linkages, springs, cables, etc. IF you see something loose or broken, check the owners manual or diagrams and remedy that. Also check out the Troubleshooting section in the owner's maual (available on-line at Husqvarna)
My problem yesterday was very simply BAD, OLD GAS. Briggs & Stratton make a pretty reliable, easy to start lawnmower engine. But even that's not enough if you're feeding it bad or contaminated gas.
Aug 11, 2012 | Garden
Remove the bowl from the carb. and blow it out with air.
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Are you getting spark first of all. If you are getting spark do you have good gas? If you have good gas most likely your carb needs some attention maybe you had some old gas sitting in there and something inside is gummed up it might need cleaning.
Sep 19, 2009 | Poulan "Poulan" Push Mower
Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Mar 20, 2009 | Champion International Champion& Small...
Petrol lawnmower cutting out.
try changing the spark plug. if that doesnt work check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal.
Aug 29, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
5,063 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
