Question about Jabra BT125 Headset
I can't get the device [Jabra BT125] to work with the PlayStation 3
Device won't register and can't be found by PS3 when you try to register the device using normal procedures. The manual is worthless when it comes to this type of problem...needs to be re-written to reflect the use of device with the PS3, which now comes bundled with the WarHawk PS3 game software! Also, the website support has absolutely nothing to say about the device when using it with the PS3. In short?lousy support and very little foresight. Need help! [email protected]
  • Anonymous Dec 29, 2007
    my headset won't work with my ps3
You half to hold the button down until it starts flashing fast blue ,keep holding it down until the flashing blue becomes a solide blue .then you are able to pair it :)
Posted on Jan 05, 2008
I was reading in another problem how this guy lost his manuel, and used the internet manuel to get it into paring mode. You are to Hold down the call button untill it turns blue, try that and let me know what happens. Here is the site for the manuel. http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT125%20Black/Documents/User%20manual/BT125_UM_NA_EN_471.pdf
Posted on Oct 05, 2007
SOURCE:
How do i program my jabra bt125 headset to my cell phone
taken from the manual found at
1. Put the headset in pairing mode
• Make sure the headset is off .
• Press and hold the answer/end button until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT125
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 3).
3. Your phone will find the Jabra BT125
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 04, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
I got the jabra to register to ps3 but when i turn it on it won't actually turn on for me to talk with other people and to hear them talk to me...
once u have it registered to the ps3 make sure the bluetooth is on on ur XMB. Go to "Accessory Settings" and choose "Audio Device Settings"
make sure ur bluetooth is listed then highlight it  press triangle and connect it if done right a mic test will pop up and u will be able to listen to urself adjust settings as needed hope this helps
Jan 05, 2009 | Jabra BT125 Headset
Trying to hook up my jabra bt125 BT to my sanyo katana dlx
Before the search you need to hold down the power button on the headset.Keep it held down until it stops flashing,the PS3 should be able to read it.My problem is that I lost my instruction manual and don't know the pass key.Can anyone help me there?
May 12, 2008 | Jabra BT125 Headset
Registering and pairing with the ps3
Go to PS3. Accessories Setting -> Manage Bluetooth Devices -> Register New Device**
** = You need to have Jabra BT125 in Pairing Mode. Hold the button for more than 10 seconds till it's a solid blue (initially turned off). Then detect it with your PS3.
If it asks for a password it's "0000"
Mar 23, 2008 | Jabra BT125 Headset
Lost my Pass Key
Try 4 zeros = "0000"
Feb 29, 2008 | Jabra BT125 Headset
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Linking a BT125 Bluetooth to my PS3
I had the same problem trying to connect my old Jabra BT125 headset to my brothers PS3, here's what worked for me:
-Turn on the headset by holding down the button but keeping it down until a solid light comes on.
This puts the headset into discovery mode, you can the start scanning for the device and it should find it.
Jan 26, 2008 | Jabra BT125 Headset
Can't get my phone to pair with my jabra bt125
to connection to your phone or device
turn off your jabra then press and hold the big white button until the light stay on the search for your device
Dec 22, 2007 | Jabra BT125 Headset
Jabra BT125 Headset Logo
150 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
