1-2 code and wont turn on
I have a mitsu big screen ws65611. the green lite just blinks fast when i turn it on.i read all the problems on this site and learned how to get the code. it came up 1-2. what is this? is it an easy fix?
  • 5 more comments
  • rdollyhigh Apr 23, 2009
    it flashed 1-2. one then a pause then twice.it did it five times.is that a good code?
    i did unplug it for a day.then i moved it to a different room.still doin the same thing.it just flashes fast for a min or so then shuts off.ill check the code again tonight and get back to you.thank you for ur help.
  • rdollyhigh Apr 24, 2009
    i pluged it back in and the green light flashed for a minute or so.then i tried the code.it was different this time.it flashed two times fast then a pause. but that was after i pressed the reset button.i dont think it was a 2 then another code because it wasnt the same pause as before in between.at least not that i can tell. just 2 fast then a break.then 2 fast again.still just shuts off after 2 or 3 sec. and no picture. . . . . .any ideas?
    i pulled dm power board out and they dont seem to be bulged.should i replace them anyway?
    and witch ones. there are 7 of them.
    c9b01,02,03 then c9b17,18 then c9b13,14.thats the order they are in.any ideas?
  • rdollyhigh Apr 25, 2009
    i replaced the 7 caps and its stlii doin the same thing. its a 2-2 code.anything else i can look at?. . .
    did you mean 7 boards or just the 7 caps on the dm board.thats all i replaced. still just flashing fast for a min or so when i plug it in then when i turn it on it shuts off in 3 sec or so.. . .please help.
  • rdollyhigh Apr 27, 2009
    ARE THE F9A04 AND 05 FUSES ON THE DM POWER BOARD? I LOOKED ALL OVER THE BOARD FOR THEM AND DIDNT SEE THEM. ANY SCHEMATICS TO SHOW ME WHAT TO LOOK FOR?
  • rdollyhigh Apr 29, 2009
    I DOWNLOADED THE MANUAL.THANKS FOR THE LINK. IM GETTIN A 22 CODE.OR SHORT PROTECT. WHERE SHOULD I GO FROM HERE? I REPLACED THE 7 16V CAPACITORS ON THE DM POWER BOARD. ANYTHING ELSE TO LOOK FOR?
    Sergeant:
  • 197 Answers
SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
Posted on Apr 29, 2009
  • 10,594 Answers
You can download copy of service manual of WS-65611 from Manual Zone for small fee.
Service manual has all schematics and PCB drawings including part number info that make easy to trace voltages and test suspected components in circuit boards and trouble shoot any problem in TV.
Your TV seems got problem with deflection section.
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 27, 2009
    Sergeant:
  • 187 Answers
You could have a problem in the DM board assembly. First thing to do is open it and see if the DM power supply capacitors are swollen or bad. This could be a very costly repair unless you know how to solder and work on printed circuit boards. If you do not, play it safe and call in a pro to assist you in this repair. Good Luck
Posted on Apr 25, 2009
  • karthik
    karthik Apr 25, 2009
    the set is not detecting g a problem, if you can use a multimeter, Go in and find some small fuses that are marked right beside them on the board as F9A)4 and F9A05, if one or more of these are bad, you will need to replace the convergence IC's. If you have no experience with solid state repair play it safe and have an authorized repair person assist you in this repair.
  • 1,889 Answers
Check all of the fuses on all of the circuit boards their are about 7 of them
Posted on Apr 24, 2009
    Sergeant:
  • 291 Answers
It wont get solved by any resettings.its a very known problem with mitsubishi tv.
just take the DM MODULE BOX out and replace the 4 "bulged" capacitors.after changing this capacitors turn ON the tv it will blink the green lights again for 30 seconds and shut off.then wait for 1 minute to get it internally reset and then ON the tv again .it will reboot and this time it will work fine.nothing much to worry its a common problem and fixing it is cheap too as capacitors would cost just $5 each.
thanks and plse do not forget to accept the solution.
    Genius:
  • 1,847 Answers
Run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Posted on Apr 23, 2009
  • 1 more comment
  • Legin Varghese
    Legin Varghese Apr 23, 2009
    Here are the error codes, and the corresponding problem:
    12 = No error detected, check power supply.
    Did you try unplug from the wall, and replugging back after 10 min. Also try on a different wall socket, remove power surge if you have one connected.
    Let me know
    Thanks
    K
  • Legin Varghese
    Sure, let me know the status
    Thanks
    K
  • Legin Varghese
    Legin Varghese Apr 24, 2009
    Her is the complete list of code.... check this link
    http://www.hdtvoice.com/voice/showthread...
    Thanks
    K
What does it mean when green power light turns yellow and blinks on and off. tv will not come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 03, 2014 | Televison & Video
Blinking green LED lite. No power. L46wd22
Oct 08, 2014 | Televison & Video
My nintendo lite wont turn on-the green lite is on but thats all-
Which LCD is blinking?
If your top screen is blinking before cutting off, your DS lite has a problem with the bottom screen.
If the bottom screen blinks before cutting off, your DS lite has a problem with the top screen.
Can you confirm?
May 30, 2009 | Nintendo DS Lite Console
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD 57833 DLP
You problem is terminal. Look on line and read more about the blinking green light of death. Push for resolution and don't take No for an answer. Mitsu. knows there are problems.
Jan 22, 2008 | Televison & Video
Same problem - loss of picture with green bars flickering
We contacted Mitsu today in Irvine. Sounds to us like they're aware of a widespread problem with this model. Told us to get a Mitsu Tech to diagnose and fax to them the outcome and someone would contact us back within two days. Seems like so many are having the same problem and all about 2.5 to 3 yrs. old. I paid $3,500.00 for mine. I'm not going down without a fight with Mitsubishi. Thought they were #1 in the Big Screen world. CLASS ACTION LAWSUIT OR RECALL BY Mitsu should be in order....They know there is a problem with the power supply module.
Jan 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
That damn blinking light
If you can solder and know alittle about electronics, you can DIY
Jan 05, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
