Question about HP Pavilion 520N PC Desktop
Computer keeps restarting...
My HP Pavilion keeps restarting over and over, it will not let me start up on any safe mode. It will not let me reboot, I can't even start up from the last good settings. It just repeats over and over and keeps starting up. I can't access anything. I just want to reboot it to its old factory systems to be able to use it again. Any tips???
  • 1 more comment
  • domsean Apr 23, 2009
    I can't boot to BIOS. The unplugging didn't work. Thanks for the help though.
    Wow ok nevermind guys. I just restored it to its factory settings and this should be fine, thanks for all your help though.
  • mrninja
    mrninja May 11, 2010
    can you boot to the "boot menu" or the BIOS?
This is going to sound ridiculously obvious, but have you tried shutting off the power or unplugging it just when it begins to restart? That's worked for me when I had a similar problem with a different brand of computer. It sounds like a software problem, not a hardware problem. Rebooting usually solves things, unless your machine won't turn off -- in which case you have to turn it off by cutting the power. Assuming that you have your CPU plugged into a power strip, if your HP won't turn off when you hit the power button on the CPU, turn the power switch on the power strip to OFF and unplug the power strip.
Wait 10 minutes. Make sure the power strip switch is in the OFF position, then plug the power strip back in and turn on the power strip. Then turn on your computer. If you're using Windows, you should get a message on your screen that says Windows shut down abnormally and that scan disk is running to check your drive. Then Windows will either give you a choice of start-up in regular or safe mode, or else it will simply come up normally on its own. And then you should be able to check whatever settings you were interested in changing.
If this doesn't work, shut off the power switch and unplug the computer, and then call your tech guy: you have a bigger problem than rebootting Windows can solve. Good luck!
Posted on Apr 23, 2009
  • 54 Answers
It sounds like your hard drive is bad. You can buy a new hard drive or you can try SpinRite I love this program and has fixed so many issues.
you can find SpinRite here http://www.grc.com/sr/spinrite.htm
  • Andrew Apr 23, 2009
    it sounds like your hard drive is bad. You can buy a new hard drive or you can try SpinRite I love this program and has fixed so many issues.
    you can find SpinRite herehttp://www.grc.com/sr/spinrite.htm
I do not know how to do a safe restart on my hp pavilion a1520n
Restart the computer. As it's booting up, keep tapping the f8 key over and over until the boot screen appears. From there, you can select from the menu for it to boot into safe mode.
Mar 07, 2011 | HP Pavilion a1520n PC Desktop
Graphic card problem..i try to install driver but everytime after thah when i restart comp it show some blue screen??? computer dont want accept any driver
I think you have installed the wrong driver, restart in safe mode by rebooting laptop and tapping F8 key when you see the HP Splash screen, uninstall driver and reboot.
Feb 10, 2011 | HP Pavilion dv9330us Notebook
My hp dv 9000 pavilion shows blank screen with cursor how do I fix this
These are the steps that you need to take, and the instructions on how to do it:
1. Reboot into Safemode
2. Run a virus and spyware scanner
3. Defrag
4. Scandisk
5. Registry error repairing
6.Reboot into regular mode windows
Here is how to do it:
Reboot yor machine while holding the F8 key right as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
Windows will start in safe mode. Run an AVG virus scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
PRINT THESE INSTRUCTIONS AND KEEP A COPY NEAR YOUR SYSTEM FOR FUTURE PROBLEMS. THIS SERIES OF STEPS CAN FIX MANY PROBLEMS
Good luck.
James.
------PLEASE RATE THIS ADVICE WITH 4 THUMBS UP!!!-----
Apr 25, 2010 | HP Pavilion dv9000z Notebook
How to exit from safe mode ?
You just have to restart the computer again and if prompted, select the option to start normally.
Sep 17, 2009 | HP Pavilion Elite M9150F Desktop PC
I cant seem to log on
try starting in safe mode. hold down f8 when you turn on your computer until you get a menu with the option to boot in safe mode. once you successfully log on in safe mode, restart your computer and the problem should be cleared. if not, we can explore further options.
Aug 14, 2009 | HP Pavilion dv9000z Notebook
I have a HP a0310n desktop. I is rebooting in a
Well you can try in safe mode with command prompt and than
To start System Restore using the Command prompt, follow these steps:
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
See if that works
Jul 31, 2009 | HP Pavilion a1310n PC Desktop
HP dv8000 w/vista keeps restarting and the monitor is blackl
Try to boot into vista's safe mode, this can usually be done by pressing F8 after POST, but before you see the vista loading screen.
Once in safe mode go to:
Start > Control Panel > System
on the left you will see " Advanced System Settings " Click that
a new window will pop up with your system properties, click the " settings " button near " startup and recovery "
Make sure the little check-mark near " restart automaticly " is NOT check, then apply, and OK out of all screeens and reboot the system. If the problem persist, you may need to insert the Vista disk into your system, and do a recovery, or restore.
May 30, 2009 | HP Pavilion A730N (PJ510AA) PC Desktop
I was searching on Google for sermons on abortion. I had gone to several websites when a ''warning'' window opened from my AVG virus protector program. While I was reading the ''options'' as to what I...
try booting into safe mode? on a pc hit F8 repeatedly while you boot until you get a boot screen with the safe mode option. Some laptops have differant keys, eg F2, <Del>, F10, but ussualy they state this when it boots up.
when you get into safe mode, go to your run prompt and type "msconfig" hit enter. got to startup, disable all.Go to services, disable all. reboot. if this works, try running an pdated antivirus scan. I recommend using Avast! which is like AVG. It can do a start up scan. also try running something like 'trojan remover' which is free to download.
Good luck! :)
Jan 05, 2009 | HP Pavilion dv6000z Notebook
Usb ports not working
hi,
What device are you trying to connect? was there an error message when you plug in the usb device. try booting up your computer to safe mode with networking.
1. Restart the computer
2. Keep on tapping F8 when you have the HP logo screen, using the down/up arrow of the keyboard choose safe mode with networking. if the device still not working then it could be a problem with the USB driver. You may try restoring your computer back to the working time using system restore. Just go to start then Accessories - System tools- system restore.Restore your computer to a working date.
Keep me posted.
Thanks.
Nov 10, 2008 | HP Pavilion dv6000z Notebook
Hp lap top will not reboot, restart nor retore
No power or computer does not turn on. Issue: No power or computer does not turn on.
Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Index
Resolved
Dec 06, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion 520N  PC Desktop Logo
250 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
