Question about Motorola Mobility SLVR L7 Cellular Phone
L7 Camera Lens
On the SLVR, the lens is on the back of the camera. Lately, when I've tried to take pictures, they've been really grainy and hard to focus. I noticed that the lens has some sort of dirt or dust or something on it, but it's under the top glass. How do I fix this, or clean it?
    Problem Solver:
  • 7 Answers
Remove back cover. Once removed you will see four screws they need to be removed using a T6 screwdriver. After removing the screws carefully remove the panel. Turn the panel over and clean the inside of the lens cover. Use either a soft bristled brush or a lens cloth to clean. After cleaning reassemble and test it out.
Posted on Sep 24, 2007
SOURCE:
My camera was dropped and now the aperture is messed up, giving me really dark and grainy pictures in bright surroundings, even set as low as 25.
i suggest you take the camera to a digital Canon repair shop and ask them for a repair quote. They may charge for a quote unless you go ahead with the repair, then you can decide whether to get a new body or get it repaired.
Sep 27, 2012 | Canon EOS Rebel XSi Digital Camera
How to disassemble lens on a casio exilim ex-z75
Jim, I really wouldn't recommend this. It requires extreme patience and meticulous parts tracking. Note that junctions stated: "It's really hard to take apart,", and he ain't kidding.
Really recommend that you return to the remedies that you had been trying. Sometimes it requires many repeated tries to free the gunk from the shutter. I've found that for the smaller pocket cameras that the most effective solution seems to be extending the lens and tapping around the lens barrel with a pen/pencil. Then alternately opening the battery door with the camera turned on (no need to play with shutter modes). Then just alternate with tapping, battery door, tapping, battery door, and keep doing this until the shutter opens/closes. Once this happens, set the camera to continuous shutter mode and snap off about 100 pictures to final lubricate the shutter.Good Luck,t00nz aka CR
Nov 22, 2011 | Casio Exilim EX-Z750 Digital Camera
What image resolution should i be using for regular 4x6 prints i have a 10.1 megapixel camera, but my pics still look grainy
Your pictures should not be looking grainy. Are they printed grainy but look clear on your screen. If so then it's just your printer. Try forcing the flash in the highest resolution. If you video's are grainy too then there is possibly something wrong with your camera. Make sure your lens is really clean. Worst case your CCD sensor inside your camera could be bad. Hope not!
Sep 20, 2010 | Casio EX-Z1050 Digital Camera
When I turn the camera on the zoom will cycle in and out a few times then i'm told to shut off the camera and restart. I can view pictures taken previously, but not taking any pictures lately.
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 03, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
Grainy pictures
I have had this on my camera,
I took it apart and cleaned all the lens from behind and it took perfect pictures.
You best bet is to google the service manual, and see were you can go from there. if not take it to a local repair store.
Hope this helps.
Thanks
Feb 26, 2009 | Kodak Easyshare M753 Digital Camera
Center of picture is soft (out of focus)
paulc846,
There might just be a smudge or fingerprint on the lens, that's enough to cause that to happen to the center of an image. Get some lens cloth on a q-tip and try to gently wipe it clean. If the image is really grainy and the camera has recently been dropped the sensor is damaged. Let's hope for the smudge.
randy320sgi
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Grainy, Spot Filled Images when using Manual Modes Only
It sounds like the aperture is getting set very high. If the aperture is a high number, the lens opening is very small which lets less light in and would cause a dark image. This would also show any dust that is in or on the lens or image sensor. The dust doesn't usually show on apertures with a larger opening (smaller number). Make sure your aperture is being set to a reasonable number, probably no higher than 8 or so.
Oct 29, 2008 | Canon EOS-20D Body only Digital Camera
Pictures are blurry; quality of photos seem compromised
As simple as this may sound, have you cleaned the lens lately? A lot of image quality deterioration comes from a finger print or other smudge on the lens. Digital cameras are succeptable to even the smallest gunk on the lens. Because the lens element is very tiny, use a cotton swab with a drop of lens cleaner (or isopropyl alcohol) to thouroughly clean and dry the lens. If it isn't a dirty lens, check your file-size and flash settings.
May 06, 2008 | Canon PowerShot A95 Digital Camera
Blurring/grainy pictures, and lens error
hi
here are some tips that may be the reason why you are having those blurry, grainy and yellowish pics.
It is important to keep your lens away from excessive heat (i.e., hot car in summertime or a heat source in a home). This will help prevent the greases, used in most lens barrels, from breaking down into an oil that can run inside your lens and cause overexposure by slowing down the diaphragm.
Use rear element lens caps on your lenses when they are not on the body. Wide angle lenses, by design, have rear elements that extend out farther then the lens barrel and are susceptible to wear, which can ruin sharpness.
Always use a filter or lens shade (hood) to protect the front element.
Never, ever, oil your lens. A minute amount of oil on the diaphragm blades will cause them to operate slowly.
hope this helps
Jan 22, 2008 | Casio Exilim EX-Z750 Digital Camera
Replacement lens for Motorola SLVR L7
go to you tube Motorola L7 - Rear Lower Removal - Repair Tutorial
its easy.
Nov 18, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
