Question about Dryers
Will not turn on
I have a kenmore 80 series, the heating element went out replaced worked fine for about 3 days. Now the dryer won't come on, I tryed a new timer that did not help. Please help!
  • booksatourpl Apr 23, 2009
    Would this make the dryer not come on at all? Thanks!
  • 70 Answers
If you replaced heating coils, and did not space them out properly, they could have went bad again. A weak spot in the coil breaks, and falls down, touching the good one and burning out both of them.
Posted on Apr 23, 2009
  • commissiondr Apr 23, 2009
    Check power supply. (breaker) Door switch would be next. If the timer runs, you may have a broken belt, ceasing to turn the motor and rotate the drum. The old GE commercial machines used to have a limit switch that would cause the motor to stop if the belt broke. This was to prevent fires, motor burn out, etc. If this dryer is fairly new, you may have this same safety set up on yours.
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I HAVE kENMORE GAS DRYER SERIES 80. last week dryer would heat for a minute then go out. Dryer would spin with no heat. Wnt to appliance store told me to change heater fillaments that one was bad after...
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 17, 2011 | Dryers
Kenmore 80 series dryer. was working fine, now
Hello. When ever a dryer will not turn the first thing to suspect is a broken dryer belt. lift the top on your machine and visually inspect the belt. If it is broken, it is easy to replace. Joe
Apr 21, 2010 | Dryers
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
the heat thermostat are not functioning well/need to replace parts.
Dec 31, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
247 people viewed this question
Top Dryers Experts
