Question about Yamaha YST-SW015 Subwoofer
Blown resister #46 need resistance value or color bands
Resister 46 has blown and i cant tell what the color bands are i either need them or the resistance value and tolerance
From what if read number r46 is 150ohm im looking for the value of r45 hope it helps
Posted on Feb 04, 2010
  • tr4b33r Jul 25, 2011
    But there's a reason why it is burnt. In my case problem was with STS 404-070 power amplifier. Changed it and resistor and it works again.
Need Schematics for Mackie C300 Speaker
Do you have the existing resistor, Larry? Is it crisped up, or can you still read the colored bands? Those colored bands are a color code indicating its resistance - if you can read them off here, we can tell you what its resistance is.
As to wattage... that's something we could at least estimate from size & shape, weighted a little by speaker wattage rating (that resistor should never see as much wattage as the rating).
Last... if we knew for sure what every other component is (from its printed labeling), we could reconstruct the schematic and calculate that resistor's value. Reverse-engineering a crossover designs is far from being rocket surgery. 8)
I offer these as alternative approaches; it may be near-impossible or impossible to get that schematic.
Aug 04, 2014 | Mackie C300Z passive PA speaker (with )
When choosing an exercise band, how do I know which resistance level is right for me?
I found you a great chart that describes various resistance levels and what they are recommended for. Keep in mind, although most color indicators are standard, there may be some companies that have chosen to color their resistance bands slightly differently. It is important to ask what level of strength and resistance each band has before purchasing.
http://www.ballsnbands.com/exercise_band_resistance_guide.html
Aug 06, 2012 | Exercise & Fitness
What are the different sizes of exercise bands?
Exercise bands are available in different sizes, shapes and resistance levels. Not only are the exercise band lengths different, but so are the colors. The colors are often used to indicate the resistance level. Some bands have handles that can accommodate more than a single rubber length.
Jul 09, 2012 | Exercise & Fitness
My KICKER amp KX200.2 has a resistor blown out it is R17 i will like to know the specific resistance so i can replace it
If you look closely at the color bands on the resistor. That will tell you what resistor you need to replace. All resistors are standardized color coded. You can find out the resistance online. Hope this helps.
Aug 14, 2011 | Car Audio & Video
I want to know what is the resistance value R32 - marshall g15rCD 15 watts
The value of r32 on the g15r cd amp is 10 Ohms 1/4 watt Brown-Black-Black
Dec 20, 2009 | Marshall 15 Watt Guitar Amp
Hitachi 51GWX20B Rear projection HD tv, convergenance/color issue
I bet you have a open resistor for the blue sub yoke. Typically it would be a 2.2 omh or a 1.5 ohm. Some times it is hard to tell buy looking at them. It you have a Ohm Meter, unplug the set, pull the sub yoke plugs from there connectors.(They are the plugs right behind the heat-sinks) . If you know the resister color code it will be a must to determin if any are open or increased in value. If you see a resister that has two red bands and two gold bands, it it a 2.2 ohm. A resister with a brown band, green band, and two gold bands is a 1.5 ohm. On some occasions, you will see a brown band, a white band and two gold bands, this is a 1.8 ohm. This circuit does not give much leeway for subing with wrong values and it even could cause premature failure if the IC's again. One last thing, double check that all the pins made it through the board when mounting and are not touching each other top side of board. As far as the one side of the picture pulling in , I think it is all related. I have seen defective STK392-150's new out of the bag.
Well thats all I can tell you at this point.
Good Luck,
Skyassoc
Jun 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Projection tv 42" panosonic hdtv. to much green in the picture. Jeff
this unit may have a resistor on the green crt-board that has increased in value. check ohms(resistance) on all crt boards and compare to one another. these will have color bands that inicate value of resistance. you do not need to know color code, just match colors of resistors on each board then measure. you could also have weak green tube. turning down the master screen control located on the fous/screen block can reduce grn. drive. to adjust proper drive for each so the grey scale is correct, turn color to tv all the way down then adjust screen controls on block for black & white picture. when color is turned all the way down, you should not have any green, red, or blue over cast on screen. mch
Feb 20, 2009 | Panasonic PT-51G35 51" Rear Projection...
Width problem
Sometimes you will need to reinforce the whole circuit with new soldering metal as well. Mass produced circuitry sometimes uses very little of the stuff or uses soldering metal of poor quality.
Apr 09, 2007 | LG Studioworks 563N 15" CRT Monitor
BLACK SCREEN
you could be having some problems in the HT area. look for a burnt low value resister that is around the fly back transformer. the value of the resistor is marked by their color. so look and check the resisters that have gold on the third band of its color.
Nov 03, 2006 | JVC AV-36980 36" TV
Yamaha YST-SW015 Subwoofer Logo
420 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
