Venturer sts20s ic problems?
Recently i found my old venturer sts20s 5.1, had it fix bout 5 years ago n the guy was only able to make left n right outputs because he was missing a part. thing is i opened it n saw a missing ta8258h ic, so i ordered 1 an soldered it still no sound from center or sub. i dont know what he did when he fixed it, nor is he available.
if i put input left n right , sound deteriorates, but ifi put only left or right sounds normal.
how can i fix this, can i test the ta8258h ic with a multimeter?
what would be symptoms of a bad ba05st and b1566 ic
  • 557 Answers
Hello:
you can not check a ic (intergal electronic circuit) with a multi meter the chip need power to 2 pins and so the chip wil works only check with a scoop for richt outputs and signals
Posted on Oct 18, 2009
Had an old friend back stabb me years ago, with my old business partner. Now like to go back into business, but he has all the contacts I need, should I swallow my pride and ask him for help?
Just tell him your starting a new venture and need to speak with so and so and ask if he has their info or knows someone that does. You dont have to like the guy you just gotta get your (you know what goes here) done.
Nov 01, 2017 | The Computers & Internet
Hi, i have a sony 43ht20 bought new the year they came out... 2002 i believe. it ran great for a few years then bam, wouldnt turn on. ordered the manual and found the problem to be a 5v undervoltage on the...
the fuse or fuses that will be bad are on the G board which is located to the left of the tv that stands vertically. on the D board the 2 convergence amplifiers are screwed into the 2 large aluminum heat sinks that have the thin metal fins part number STK392-560 can use STK392-570. most repair shops mine included charge around $300.00 for repair if you have soldering skills then the component parts replacement is the cheapest way to go. the entire Dboard runs about $215 nowadays and the convegence amps run around $40-50 a piece plus $5 for the pico fuses.
Jan 05, 2011 | Sony KP-43HT20 43" Rear Projection...
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Our HTR-5660 is about 5 years old. Recently it
I solved the problem by ensuring the Impedence selector was either all the way to the left or all the way to the right, as instructed in the manual.
Jan 19, 2010 | Yamaha HTR-5660 Receiver
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Sony KP-53XBR45 convergence
Hey, found the problem. Your Convergence IC chip went bad. Buy one at Bluestar International Components (bluestar-online.com) - order part number STK392-010 for 6.99. I've read that there are two in the system and replacing them both at same time is a good idea...so, order 2. Now, if you are handy, it will require you to open the back of the TV and solder out the old chip and replace with new. If not, then you might as well call a TV repair person and have them fix. However, every place I've called works on a minimum fee for "large screen TVs" - the cheapest I could find in Atlanta was $399 minimum service fee. So, I'm going to risk the home sodering job .... it's a 10 year old TV and as good as it's been to me, if I screw it up, I feel I've gotten my money out of it. Good luck with your repair. My parts are on order.
Oct 15, 2008 | Sony KP-53XBR45 53" Rear Projection...
No sound on analog inputs, digital sound is ok
1) IT02 Shorted, pins 92 and 93
Cause: Solder splash
2) IT05 pins 20 & 21 shorted.
Cause: Seems to have been cause by too much solder.
3) IT02 was found to be defective.
Cause: Defective component.
4) IS11 missing circuit trace.
Cause: Caused by some one that replaced/removed this IC previously.
5) IT02 solder, pins 42, 43 & 44
Cause: Two boards found with these same pins with cracked solder
6) IS13, pins 1 & 2 shorted
7) Audio Quits when board is tapped.
Cause: Soldered all IC's on bottom of board. Also soldered IT04, I516, I517, I510, I501.
8) Also, please resolder IT05 and IT06
9) Check for cracked patterns under IT05
Dec 10, 2007 | Hitachi 53SWX12B 53" Rear Projection...
134 people viewed this question
 Grubhead
Grubhead
