Question about HP LaserJet M1522n MultiFunction Printer
Printing speed problem
Hi, I have a HP Laserjet M1522n, and the first times I used it the printing speed was OK, but after a few times, it started functioning very very slow. For example, I send a 24 pages document, and it prints it like page by page, 1 page, then it stops, and then another.
Is there any way to fix this problem?
  • 54 Answers
Laserjets have limited amount of ram to keep large docs in memory, you can increase the document or in windows have it spool on your machine first.
Posted on Apr 23, 2009
1 Answer error 50.3 on hp m1522n we turned off then on, but error still continue.
A 50.3 error means that the temperature of the fuser got to high.
Just try switching it of for 20 minutes and try again.
If it happens during a large print job, this may help, if the error returns when powering up the machine, the fuser is faulty, but if so, that means it would have to be replaced.
If you are printing narrow media (A5, envelopes) etc. try printing them in small batches,, and allow the printer to cool of in between batches.
May 26, 2014 | HP LaserJet M1522n MultiFunction Printer
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
I have a HP LaserJet M1522N Multifunction printer. It has been installed for some time and no settings have been changed. It has randomly started to say "Failed to Print" in XP despite having no...
Are you using USB or a network connection?
If it's USB use a different port on the computer.
If you can, try it on a different computer
Print out the Event Log. See if any errors are showing.
Sounds like you have an idea of what you are doing.
Jan 11, 2011 | HP LaserJet M1522n MultiFunction Printer
Speed
Hi, your printer basically printing speed is 43 ppm, please see:
http://h10010.www1.hp.com/wwpc/hk/en/sm/WF06b/18972-18972-3328059-236263-236263-412144-412150.html
so sometimes the print speed depends on your print file size and the PC process ability for large file. large file printing at lower speed right. so you do not worry it.
is it help you? please feed back any question.
May 12, 2009 | HP LaserJet 4250n Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Hp laserjet p1006 printing jobs gets struck in printing queue
I know this problems in my part it was the hp driver.
My Solution is to use an compatible driver.
HP Laserjet 5 / or 6 standard windows driver.
After that i have not this problems.
The secound problem is that this printer have very less memory and big pages in a few times are not able to print.
Dec 25, 2008 | HP LASERJET P1006 Printer
HP LaserJet M1522n MultiFunction Printer Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
